Here is there Support. Contact is at the bottom of the page.
Technogym Customer Support
Technogym
https://support.technogym.com
Technogym Customer Support is where you will find all the answers to your frequently asked questions, articles and useful resources to help you to get the ...
I also found this
A message stating 'the equipment is blocked' essentially means that a problem was detected that *might* be a blockage against moving of the moving parts. This commonly can be owing to two things:
1. the upper and lower assemblies (i.e the upper is the console, the lower is the electronics or boards in the lower part of the treadmill, e.g. the motor controller board and brake board) have a fault in the communication between them. This indicates first that you need to check the cable between console and lower assemblies, and also to re-seat either end, or at minimum make sure there is no breakage or crimping in that cable or wire harness, between console and lower assembly and lower boards.
or
2. the error was detected by the brake board, and one must go through the error procedure for a brake board error.
(In some models, (2) requires accessing the Low Kit Menu, to see whether there is a genuine error registered in the Low Kit Fault area of memory.)
Also
3. you might unplug it from power while it is On, and see how that works, after about 2 hours unplugged, please.
