Euro-Pro Dressmaker 998B Logo
Posted on Jun 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Thread Underside Of Sewing Material Bunches Up When You Start To Sew On This Dressmaker Deluxe Sewing Machine Goes 1-1/2" Long Then Jams Machine, How Do I Fix This Problem? Model #swa2000
Hassy
Level 3:
  • Euro-Pro Master 1,388 Answers
  • Posted on Oct 18, 2011
Hassy
Euro-Pro Master
Level 3:
Answers
1388
Questions
Helped
496210
Points
2943
For a comprehensive 5 page illustrated tutorial...Check this link
Anonymous
Level 2:
  • Expert 111 Answers
  • Posted on Jun 11, 2009
Anonymous
Expert
Level 2:
Answers
111
Questions
0
Helped
36535
Points
179
Bunching of thread under the material means that there is no upper tension. make sure the upper threading is correct.
2answers
Bobbin thread bunches up under material
make sure that the bobbin carrier is fixed in properly
make the needle thread tension a lot tighter
1helpful
The top thread just hangs and knots on bottom of material
try changing the needle-flat side goes to the back of the machine
check to see if the thread has come off the thread take up lever
try rethreading the machine top thread & bobbin
clean under the needle plate area & also in the bobbin area for lint or loose threads
Whenever I sew the top thread breaks. The machine seems to sew but then jams when I take the material off the top theard is all cut on the underside of the fabric and the bobbin thread is just there. ...
to see if a needle & thread are compatable, take a strand of the thread your going to use & the needle your going to sew with & put the thread thru the eye of the needle & hold it at a 90 degree angle & see if the needle goes down the thread easily
check the needle plate to see if there's any burrs or sharp edges & the bobbin case also
make sure the top thread does not come off the thread take up lever,cause that can make it jam also
it also possible that the machine could be out of time & would need to be serviced at a repair shop
2helpful
Dressmaker 2 Date 2608 thread snarled on underside of material. Sewing on one layer of cotten.
Here are a couple of things to try.
- Re-thread your machine, it may be threaded incorrectly.
- Raise your feed dogs if your machine has this feature.
Note:
when you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
Hope this helps.
1helpful
How do i keep the thread from gathering on the underside of the material The thread bunches and breaks. thought it might be the tension but can't seem to fix. I cleaned the bobbin areas.
Here are some solutions for you to try.
* Re-thread your machine, it may be threaded incorrectly.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold onto the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
I am having trouble with my bobbin . When I put into the sewing machine and begin to sew the cotton just bunches up and jams . Any suggestions
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
Hope this helps.
2answers
Time janome 3018?
when you say 'bobbin thread bunches' i take it that when you look at the underside of what you have sewn it looks messy. if this is the case and the machine is threaded correctly and the the needle thread is tight enough to bend the needle a little when pulled (with presser foot down) it will most likely be that you need to increase needle tension (maybe to max) when sewing thick fabrics with thicker than normal thread.
if the the needle does not bend a little you may not have the thread in between the tension discs, or there may be thread or lint caught in the tension discs preventing proper tension (try pulling a thin rag through the tension discs to dis-lodge any foreign matter).
scott.
4helpful
4answers
Singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Bobbin holder doesn't spin
Be really sure that the thread is threaded properly. Correct size needle for the material, and no cheaper thread. It does make a difference.
2helpful
Pfaff sewing machine
You don't have the thread in the take up lever or it is not in the tension. Rethread it , Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.
set your tension to 5 and try it.
sewman7
Top Euro-Pro Sewing Machines Experts
Mike Cairns
Mike Cairns
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
