Question about Genie Company IntelliCode GICT390-1BL Remote Control
Genie remote gict390 battery replacement and reset
The remote is not working after replacing the 3 volts battery. Is there a reset switch inside the remote.
5 Suggested Answers
SOURCE: Reprogramming a Genie garage door receiver
I ned a akai audio timer DT-100
Posted on Aug 18, 2009
SOURCE: change battery in GICT390 3 button remote
If its a lighter grey colored intellicode remote: There should be a small slot on the side of the remote. Use a coin such as a dime or a penny, stick it in the slot and twist. The remote should split in half and you'll see the coin-shaped battery. After you replace the battery, you can snap the 2 pieces of the remote back together.
If its a dark grey/black intellicode remote: The back cover should partially flip open to reveal the battery. This remote takes a 12volt N-size battery.
If its a keypad remote you are referring to: The bottom half of the keypad's face should slide straight down to reveal the battery (you should see and arrow and some thumb grips). All Genie keypads take 9volt batteries.
Posted on Nov 20, 2009
SOURCE: how do you replace the battery in the genie garage
Never could get mine to work...turns out this model only works with Genie garage door openers manufactured in certain years, and mine wasn't one of those years. Bought a GIT model from a Genie garage door installer, and no more problems!
  • 4 Answers
SOURCE: How do I change he
Take a flathead screwdriver and pry the two halves out the casing open. Remove the circuit board completely from both halves of the shell to get to the battery.
Posted on Sep 17, 2010
What is the battery size for a genie garage door remote opener model gict390
The GICT390-1 (one button remote) and the GICT390-3 (three button remote) both use a 2032 coin cell battery.
The manual for the GICT390-3 is available from Genie on their Programming Accessories page: http://www.geniecompany.com/garage-door-openers/programming_accessories.aspx . The direct link to the instructions is: http://www.geniecompany.com/data/products/accessories/manuals/legacy/36484U_1-Btn%20IC1,%20390_3577435796.pdf .
I hope this helps.
Feb 25, 2015 | Televison & Video
What size battery is used in the genie gitc390 remote
i buy a new battery for my genie gitc390 garage opener but still doesn't work, the red light is on when i press the button. what's the problem?
Nov 14, 2012 | Genie Company IntelliCode GICT390-1BL...
Genie g3t-r remote seems like it 's programmed but doesn't open door. led's suggest it was programmed.
1) test the batteries 2) rETIGHT THE spring contact batteries 3) Resolder wires for contact batteries, see if there are some wires missing. 4) Try again with the codes.
go www. fitness.manualsonline.com get the code , and reset again.
Otherwise the remote control you must go to the repair shop.
God bless you
May 09, 2012 | Genie Company IntelliCode GICT390-1BL...
How to replace the battery on Genie ACSCTG Type 1
http://www.geniecompany.com/support_technical-faq.aspx
Call the number on this link to the company which it seems does not offer owner manuals online--if you have the manual it will have battery replacement instructions and type of battery used.
May 01, 2012 | Genie Company IntelliCode GICT390-1BL...
I have the gict390 - 1 button--- it used to work on my garage - doesn't anymore. Wife's remote still works. Tried reprogramming - didn't work. The led on it still works & haven't had it that long...
My remote stopped working and the light still came on as well. Replaced the battery and it's working again. Try the battery. Tip: when I took the shell apart, I had to take the circuit board completely out of both halves of the shell to get to the battery.
Sep 14, 2010 | Genie Company IntelliCode GICT390-1BL...
How do I change he battery in the genie gict390
Sep 05, 2010 | Genie Company IntelliCode GICT390-1BL...
Can the battery in the Genie GICT-1BL remote be replaced? If so what is the battery description and how is it done?
The battery can be changed. There is a divet on the side of the unit. Insert a flat screw driver and pop it apart. There is a number on the battery. I believe it is 2032. The number on the battery cannot be switched although other ones look like it. Thanks BB
Jan 16, 2010 | Genie Company IntelliCode GICT390-1BL...
How do you replace the battery in the genie garage door remote, its the small one
Oct 28, 2009 | Genie Company IntelliCode GICT390-1BL...
I need to replace the battery on a Genie GICT-390 garage door opener. How do I open the case?
If its a keypad remote you are referring to: The bottom half of the keypad's face should slide straight down to reveal the battery (you should see and arrow and some thumb grips). All Genie keypads take 9volt batteries. Source(s): I am a genie technician
Oct 24, 2009 | Genie Company IntelliCode GICT390-1BL...
Change battery in GICT390 3 button remote
Oct 10, 2009 | Genie Company IntelliCode GICT390-1BL...
Genie Company IntelliCode GICT390-1BL Remote Control Logo
65 people viewed this question
Top Genie Company Televison & Video Experts
Dan Apthorp
Leonard Manamela
Leonard Manamela
Are you a Genie Company Televison and Video Expert? Answer questions, earn points and help others
