Question about Xerox 8850 Led Printer
LL 22 error code
LL 22
2 Suggested Answers
  • 51 Answers
SOURCE: How would I correct
clean or replace transferand detack coroton wires
Posted on Dec 12, 2010
Error code 22
"Error 22" on a Pioneer usually means an unsupported CD format. The disc you are trying to play is not supported or is very badly scratched so the player cannot determine the format.
Dec 19, 2013 | Pioneer Car Audio & Video
Error code p0077 p/d
Hi there:
P0077 - Intake Valve Control Solenoid Circuit High (Bank 1)
Check in this link page 22: FSM//H4SO%20Engine/GD(H4SO)%20General%20Desc.pdf
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 20, 2012 | 2006 Kia Rio
WBVH6240F trouble codes 22 & 70
WH12X10355, this is the part number you are going to need to repair the washer
May 06, 2012 | GE WBVH6240F Front Load Washer
I have SandDisk S3 UCL Mode USB Device which is not detecting right now. One week back its working fine. In computer management i found device has in diabled mode. when i try to make it enable its again...
How to Fix a Code 22 Error
  1. Enable the device. Since the most common reason you'll see a Code 22 error in Device Manager is because the device has been manually disabled, try manually enabling it.
    Most of the time this will fix a Code 22 issue. Don't worry if it doesn't, however. All that means is that the Code 22 you're seeing was caused by something a bit less common.
  1. Restart your computer if you haven't already.
    There's always the chance that the error Code 22 you're seeing on a device was caused by a temporary problem with the hardware. If so, a restart of your computer might be all you need to fix the Code 22 error.
  2. Did you install a device or make a change in Device Manager just before the Code 22 error appeared? If so, it's highly likely that the change you made caused the Code 22 error.
    Undo the change if you can, restart your PC, and then check again for the Code 22 error.
    Depending on the changes you made, some solutions might include:
  1. Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is one possible solution to a Code 22 error.
    Important: If a USB device is generating the Code 22 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
    Note: Correctly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
  2. Update the drivers for the device. It's also possible that installing the latest drivers for the device could correct the Code 22 error.
    If updating the drivers does remove the Code 22 error, it means that the stored Windows drivers you reinstalled in the previous step were either damaged or were the wrong drivers.
  3. Clear CMOS. If Windows had to disable the device, generating the Code 22 error due to a lack of system resources, clearing CMOS might fix the problem.
  4. Update BIOS. Another possibility is that a newer BIOS version could better pass system resource handling to Windows, correcting the Code 22 error.
  1. Move the device to a different expansion slot on the motherboard, assuming of course that the piece of hardware with the Code 22 error is an expansion card of some kind.
    If the Code 22 error is due to a lack of system resources available for the card, moving it to a different slot on the motherboard could clear up the problem. This isn't as common a situation with newer hardware and Windows versions but it is possible and is an easy troubleshooting step to try.
  2. Replace the hardware. A problem with the device itself might be the root cause of the Code 22 error, in which case replacing the hardware is the next logical step.
    While not likely, another possibility is that the device is incompatible with your version of Windows. You can always check the Windows HCL to be sure.
    Note: If you're positive that the hardware is working properly and is properly configured then you might consider a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either before you replace the hardware, but you may have to give them a try if you're out of other options.
Please let me know if you've fixed a Code 22 error in a way I haven't mentioned above. I'd like to keep this page as accurate as possible.
What Does the Code 22 Error Apply to?
The Code 22 error could apply to any hardware device managed by Device Manager.
Any of Microsoft's operating systems could experience a Code 22 Device Manager error including Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP, and more.
Still Having Code 22 Issues in Device Manager?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more.
Be sure to let me know that the exact error you're receiving is the Code 22 error in Device Manager. Also, please let us know what steps you've already taken to try to fix the problem.
Show Full Article
Aug 03, 2017 | Computers & Internet
Error code E01-22
The error E01-22 means polygon motor synchronization error.
The possible causes for the error is problem with ;
- engine pcb
- laser unit
- lvps
- sc pcb
You can try to reseat the connectors, else you may need to replace the board.
Nov 04, 2010 | Panasonic Office Equipment & Supplies
I have a ..tvr608 hi 8 camera..the code c:31:22..i tried removing tape and letting sit open for 24 hrs to dry (per manual) nothing..any suggestions??seems like " tape drive " is slipping..if...
Hi
Thanks for using FixYa. Error C 31:22 is caused due to bad Gear assembly, to resolve this issue with the battery &cassette removed try whacking the camera sideways, if after doing this still the issue is not resolved then you’ll have to get the Gear assembly replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 13, 2010 | Sony Video Cameras
How would I correct a LL - 22 error code?
Sep 06, 2010 | Xerox 8825 Copier
How do you fix Status Code LL-22
‘LL-22’: High Voltage Transfer failure. I would suggest calling your local Xerox tech.
Jun 24, 2010 | Xerox 8830 Copier
I'm setting up a 8830 and a 7356. The scanner says ready but when I put in the paper it says not ready take out the paper. The 8830 has a code LL-22, is that something I can fix?
As far as the scanner insert a sheet to copy and when it says NOT READY instead of rolling the paper out the way you put it in, roll it forward until it comes out the back.
An LL-22 is a HV power supply error. Most of the time when I see this the corotron wires are contaminated by developer. You need to clean it with a vacuum.
Nov 25, 2009 | Xerox 8830 Copier
Code (22)
Dear Customer,
There are some vital informations and solutions regarding Code (22) error..
Code 22
The text displayed for this error code differs depending on the circumstances.
  • If this device is disabled because you disabled it using Device Manager, the following text is displayed: This device is disabled. (Code 22)
    Click Enable Device to enable this device. Solution button: Enable Device
  • If the device is not started, the following text is displayed: This device is not started. (Code 22)
    Click Start Device to start this device.
    Solution button: Start Device
  • If the device is disabled by a driver or program, the following text is displayed: This device is disabled. (Code 22)
    You can't enable this device because it has been disabled by a Windows driver. Solution button: None
This code means that the device is either disabled or has not started.
To resolve this error code, follow the recommended solution. For the third case, try removing the device in Device Manager, then redetecting it using the Add New Hardware wizard. If the problem persists, try a clean boot to rule out software interference. If the error persists, contact the hardware manufacturer.
Please Rate this Solution.. Thank You..
Jul 10, 2008 | Computers & Internet
Xerox 8850 Led Printer Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
