Question about GE Profile JGP970SEKSS Stainless Steel Gas Cooktop
Fire on range top, shorted out while cleaning
Where are the fuses on a fridgidare range,glass top,everything works except thesettings for my stove doesnt light up
Thank you for your post, friend!
Based off what you have described the settings on your Frigidaire range do not light up and you would like to know the location of fuses. There are no fuses within your range, if the control panel is not lighting up it could be a short within your panel and that may need to be replaced. I would recommend having a professional technician out to disassemble your range and replace any electrical components. This will protect you from any personal injury and future issues with your range. Hopefully this information is helpful. -Matt
Mar 10, 2015 | Frigidaire Stove/Oven/Range Black Glass...
I had cooktop on low and it started making noise. The ceramic top pitted in two places. Is it still safe to use. I used a flat skillet.
Sounds like there might be a short. If you are adventurous, I would tell you to open the top and look for shorts, otherwise, you will have to replace it because of the fire hazard.
Mar 22, 2011 | General Electric 30 in. Profile PP975...
2 burners are not igniting. you can hear it ticking but no fire. can you help?
Sorry to read about your problem, I hope this helps you out.
range units need to be cleaned,, remove all grease.. use a pin to clean holes
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Jade RJDG3610A Stainless Steel Cooktop
How do you seal the edge around the flat glasstop range, so stuff doesn't run underneath it?
get fire-proof silicon and run a bead around the outside of the range and whatever your range is sitting in, e.g. bench-top.
Nov 12, 2009 | Jenn-Air JED8430 Electric Cooktop
Electric starters keep firing after I sprayed cleaner
your spark modual got shorted with the liquid you sprayed in there or spilled you can try unplugging it overnight to let it dry. at least 24 hours or you can take the cooktop of and get a hairdryer and dry out the spark modual.or if you wait 24 hours - 3 days and still not dried out you need to replace your spark modual but more than likley give it time it will fix itself.
Apr 23, 2009 | Amana AKS3040 Gas Cooktop
Stove top keeps turning off
if your breakers have become week they may trip with a lesser amp draw.sooooo if they trip right when you turn on a switch on the range, then it is a short in the range.if it trips after your using it abit its your breaker.hope it helps God bless ,tom
Jan 08, 2009 | Jenn-Air JED8230 Electric Cooktop
STAIN ON CERAMIC COOK TOP
We have a new product that is odor less and non-toxic. $8.95 a bottle + shipping. Our web site will be up shortly: debrucepolish.com I'm Bruce, can be reached at 612-220-2236
Aug 22, 2008 | Wolf Range 18 in. SPR-100 Gas Cooktop
Igniter keeps firing
The problem resolved on its own. I'm guessing some moisture from my cleaning was the culprit...when the moisture dried the igniter stopped sparking.
Jun 01, 2008 | Jenn-Air 30 in. CVG4280 Gas Cooktop
GE Profile JGP970SEKSS Stainless Steel Gas Cooktop Logo
61 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
