Question about HP 2311X 23 Widescreen LED Full Monitor - 1920x1080, 1000:1 Native,
Everytime I start my machine, when it gets to windows, the screen goes dim and, I think, booting stops
This only happens when I am putting the machine in permanently in a different location. I can run it just fine in another location. I have swapped out the power cord, and outlet, I have removed all connections but the video, I have reinstalled the driver for the monitor (hp2311x) This makes no sense at all. I have also checked my voltages which are all fine. This machine also has a new motherboard (biostar w/amd quad)
  • HP Master
  • 1,899 Answers
What PC, all you posted is a screen.
we can not guess 36 years of PCs ever. sorry
my guess is PC is not HP, only the screen
this is near new screen
turn it on, and push the screens menu button.
see the OSD screen, now? sure, and that means the screen is ok.
and the PC is dead.
so post why is PC dead,get 100 reasons.
this position (ROOM LOC?) thing fools me, totally, sounds like bad cable.
or PC has loose parts.
if the PC fails with a borrowed monitor, is bet that makes sense ,, no?
The PC turns on,
the PC makes fan sounds
the PC dvd eject button works
the PC BIOS screens wall work
stop, i stop here we go father easy past BIOS working,
the BIOS hot key will not be the HP key cause yours is not HP
Posted on Jul 13, 2017
Benimur
  • 6966 Answers
SOURCE: HP Monitor blanking out on full screen mode
Hi, I read this somewhere (can't recall the site). Go to your desktop properties (right click on any clear area of your desktop); Settings tab; Advanced button; Troubleshoot Tab; Uncheck Enable Write combining; Reboot your PC. If this does not fix the problem, you can always revert back. Hope this be of some help. Good luck and kind regards.
Posted on Jul 30, 2007
Mr BrokRench
  • 1623 Answers
SOURCE: I've been getting no power at all. Tried using a good known power cable and a different power outlet but still won't work. How can i open the panel to check the power button?
Hello emperez25...Sorry to hear that your LCD died on you. There are two things that normally cause this... #1..The power supply has gone out.... This would be the case if the lights on the front of the unit do not come on. You can check this with a multimeter. . #2...The inverter or the back lights are burned out. LCD displays use small tube florescent lights like the ones that are in stores and they either burn out or the inverter fails and they cease to work. This is the case if the front panel light comes on but no display can be seen unless you look VERY close. They can be repaired, but with parts and labor costs compared to the price drops of new LCD's most folks opt to upgrade....In short, get a written estimate for repair costs, if you choose to go that route. For less than 200 dollars you can get a NEW 23 inch LCD with DVI, HDMI and AGP interface with a full high definition display that supports the latest Blu-ray devices for FHD/HD true digital content.
Hope the information i have provided you is helpful...
Posted on May 15, 2009
micromend
  • 748 Answers
SOURCE: Same problem screen goes dark.
Hi
Well I would have thought this to be a classic failing monitor until you said even a new monitor does the same thing. This being the case it can only be the video card or drivers for the card. Resolution is easy to change and could cause the problem if the resolution selected cannot be displayed by the monitor. At the main windows screen right click the mouse and select properties. Now click the settings tab and the resolution is on the left side. Your display should also be listed.
Thanks
Posted on Jul 24, 2009
  • 788 Answers
SOURCE: blank HP w1907
If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
If in warranty, they will send you a box by FedX second day and have repaired.
This is a 19" monitor and will not be worth paying for repairs if not in warranty.
Posted on Sep 03, 2009
Testimonial: "I am very happy that this guru was able to concisely evaluate the problem from the information provided. "
  • 732 Answers
SOURCE: I have a black square on my display that seems to
Stephengibso, Have you tried removing or uninstalling the drivers one by one to determine which one might be the cause!! Can you move the monitor over to a different PC to prove that that the MONITOR is working correctly? 12fixlouie
Posted on Dec 03, 2009
My hp pavilion 513n has completely stopped working! I need help!
Start the computer, and keep pressing F8 until you get a "boot" menu -- white text on a black screen.
Select "safe mode with command-line", and see if Windows will start.
If it does, enter 'CHKDSK C: /F' to get Windows to check the integrity of the file-system.
Then, find a friend with a genuine Microsoft Windows XP CD-ROM. Boot from that disk, and choose "repair", and see if the boot-process can "repair" your installed copy.
Jun 23, 2010 | HP Pavilion 513n (P9850A#ABA) PC Desktop
I get a black screen with the mouse everytime i boot to windows
Is it black all the time? From when you start your computer to when you turn it off?
Sounds like the backlight is bad.
Aug 07, 2009 | Dell Inspiron 1720 17" Widescreen...
Screen goes black with one cursor blinking after windows loads
start your pc press del, go to cmos setting and look for primary and set it up to boot from cdrom
after you install everything
go back to the cmos and put it back in primay hardrive and that is IDE1
Aug 04, 2009 | Dell Dimension 2400 PC Desktop
No login screen
As soon as you get past the bios screen, start clicking F8 to get a boot menu. Boot into Safe Mode.
Then right click the C:\ drive and tell it to do a full disk check with repair.
It will say it has to do it on reboot. Reboot, allow disk check to run and see if the problem is fixed.
If not, put your Windows disk back in and click Start > Run > then type sfc /scannow and clikc OK.
When finished, run windows update and reapply all service packs.
Jun 25, 2009 | Microsoft Windows XP Professional
Cant get into anything at boot up
try f 2 to go into the bios and reset boot sequesnce to boot from DVD drive
May 28, 2009 | Eurocom 888es Notebook
Won't boot
Here is the cause, and I think you will have to re-install the operating system. Not knowing your machine model number, I have no idea if the operating system recovery is imbedded in the hard drive or not.
http://www.geekswhoknow.com/articles/stop-0x00000024-0x0000024-0x24-ntfs-file-sys-error-code.htm
If you receive a blue Dell line across the top of the screen during power up, press F11 to see if you can get into the recovery mode. If so, just follow the instructions.
Mar 18, 2009 | Computers & Internet
Randomly lost display on my pc.. and its not a faulty card.
Try to set your PCI-E card as a first one in BIOS. There also should be an option to turn off onboard video.
Mar 07, 2009 | Gateway GT4022 PC Desktop
Start up problem
probably u deleted some files from windows ...
after booting press F8, (or F5 ..i donlt rememdber) and then select go to safe mode! If it works than try and see what is missing, and back up u;re data.
If it doesn't work than u;ll have to reinstall u;re windows ...
Aug 08, 2008 | HP Pavilion a800n (PP163AA) PC Desktop
Personalization screen
BDEATH HERE. First turn on your motorola by pressing *# and red key at the same time to get in the boot loader mode. Then try download flashbackup 6.22 version for motorola. Visit motox site to find the best flash monster pack for your motorola. Also write down your s/w version, flex version and what boot loader your cell phone has. and get the usb cable. Up then tell me what happened!!
Sep 03, 2007 | Motorola Mobility V220
Registry file failure
If the last suggestion i posted didn't work, you need to put in your Windows CD on boot up and when it asks if you want to repair or install press 'R' for repair, this should repair any damaged registry files and Windows files.
Nov 12, 2006 | Dell Inspiron 600M Notebook
HP 2311X 23 Widescreen LED Full Monitor - 1920x1080, 1000:1 Native, Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
