Question about Sanyo DS31590 31" TV
Problem My tv turns on but when I hook the cable up to it it doesn't work. The cable works on all of the other tvs but not that one. It just shows a snowey picture
  • 373 Answers
Re: problem
You could have a bad tuner or I have found location number R106 could be open and not passing the voltage. It is a 39K resistor at half watt. The voltage goes to the tuner.
Posted on Dec 30, 2007
0 characters
3 Points
Why will my new tv not pick up any channels when using the auto channel search
It depends on if you have cable or are using an antenna. If you have cable, make sure you have the cable that runs in between them hooked up to the correct spots. If you're using an antenna, you might need to get a TV converter box. A couple of years ago, they stopped making regular TV channels and switched to only digital channels. Most older TVs don't work with digital channels, so you need a box that will convert the picture. You can get one at any place that sells TVs (walmart, amazon, etc)
Feb 02, 2015 | Standard (CRT) Televisions
I can get my cable box to work with this tv
tried with other monitor doesn't work?. if no the cable box has a problem. if yes then check this in your tv, the settings in the tv must select cable and then check the cable wire if it is good and properly hooked up at the tv.
Nov 12, 2012 | RCA 20F424T 20" TV
I hooked up cable to the back of tv but it doesn't
Set may have more than one input, you may be hooked up to the cable fitting when set is on a video input (blue screen means no signal)
Apr 04, 2012 | Mitsubishi Standard (CRT) Televisions
I lost my bratz tv remote annd i finelly got cable but need the remote to turn it on.What do i do??
Most TVs have a power button located on the front of the TV that you can push to turn it on. If your TV doesn't have one, you could buy a universal remote and use that or buy a new tv.
Jul 18, 2011 | MGA Entertainment Bratz TV
Converter box installation. Not a clue.
rf cables will work fine for older tvs. newer tvs should use the composite (yellow, red and white cable) to produce a digital picture and sound. FYI the indoor antenna works best when positioned in a window. Best thing to do is install an outdoor antenna in the attic near the gable vent or on the exterior of the house.
Jul 04, 2009 | Standard (CRT) Televisions
Samsung DLP TV and PS3 Problem
Would you please read the manual of TV & PS3 for HDMI cable's
If you match that version, can play.
Dec 27, 2008 | Samsung DLP HL-P5663W 56" TV
How to hook up cable and get more channels than 2-13????
Change setting in menu to cable from tv or antenna. May be in channel setup menu.
May 12, 2008 | Standard (CRT) Televisions
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Jul 29, 2007 | Orion1934 19" TV
Sanyo DS31590 31" TV Logo
Top Sanyo Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Sanyo Standard (CRT) Television Expert? Answer questions, earn points and help others
