Question about Jaclyn Love Home
Need to find another set of shantung thermal grommet panels rn 119053/ca 01405
I purchased what was supposed to be 2 grommet panels and it turns out there is only one. I can't tell what color it is (it's not on the packaging). I took too long to open it so I can't return it. Besides, I like it and would like to use it.
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: motor drive grommet (black rubber)
Have you tried getting in touch with the manufacturer or any of their dealers?
Should you need -
HEADQUARTER
Elna International Corp. SA
icon_mail.gif Ch. du Champ-des-Filles 19
1228 Plan-les-Ouates
Switzerland
icon_mobile.gif +41 22 884 86 66
icon_printer.gif +41 22 794 95 40
icon_mail_back.gif info@elna.com
icon_home.gif http://www.elna.com/
You can also try getting in touch with dealers or country representative here.
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 08, 2008
gdlkn84as528
  • 89 Answers
SOURCE: lexmark printer model Z2300m color printer.
its hard to diagnose power issues. try another outlet and see if it works. If you truely bought it 2 days ago, ANY store will allow you to exchange for another one whether you have a receipt or not. The only reason I know that, is because I have worked retail many years in the past and have never heard of place not letting you exchange for the same item. Unless, you bought it a garage sale or something similar.
Posted on Sep 22, 2009
SOURCE: Has never worked. Purchased;
Welcome to Fixya
Please let me know the brand and model of your motherboard
Hope to get a reply soon
Posted on Jul 05, 2011
What does error code CA on my calypso washer?
Ca - Average Current peak - happens if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Overloading the unit may cause this problem. Try washing smaller loads and see if the problem goes away. If it recurs when you wash bigger loads, decrease the size AND watch to see if you have to continue to decrease the size to keep the error from happening. If that were occurring, it could well be a sign of the electrical problems noted, requiring service.
CA Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip. Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
I think CA means [C]ontrol [A]verage Error. It means you need to reset the control panel, and retry again.
Aug 22, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
Motor drive grommet (black rubber)
Should you need -
HEADQUARTER
Switzerland
Feb 08, 2008 | Elna Heirloom Edition 6005
How do i contact the manufacturer?
Check the Wash/Size Tag, there should be a RN or CA number on the tag if it was sold in USA or CANADA. With the RN #, search for Apparel Registration at the .GOV website.
Jan 28, 2014 | Simple Pleasures Womens Plush Robe Blue...
How do i take door panel off?
remove all the hardware from inside door panel first, window roller handle or electric switch panel, and door handle, then you need to pry all the grommets out of the hole's they fit into down both sides and across the bottom, the panel then needs to come straight up and off, they make a simple little tool to pry the grommets loose, can be purchased at most any auto parts store, like shucks or Napa Harbor Freight also has them cheap.
Dec 15, 2013 | Jeep Cherokee Cars & Trucks
How to set the timing on a 1997 gmc 5.7
I would have the ignition gears inspected, gears can wear out and cause this. If bad gears are found I would then inspect the camshaft for worn gears as well since the camshaft spins the ignition.
Mar 29, 2013 | 1997 GMC Yukon
Transmission is leaking from my 2008 ford escape. The VIN number does show that it was manufactured in Kansas, but because i am in Canada the recall did not include canadian owners.
What do you need? I would cantact Ford of Canada in back of owner manual with letter, not phone, if issue is the same. TEXT:
In some of the affected vehicles, the transmission fluid cooler may develop a crack in the tube below the right hand (RH) mounting bracket from thermal and vibration fatigue. This may lead to a small transmission fluid leak and possible rough / harsh shifts. Dealers are to inspect the transmission fluid cooler for a grommet and possible fluid leak below the RH mounting bracket. Based on the results of the inspection, dealers will perform one of the following service
actions:
INSPECTION
1. Using a suitable light, look through the radiator grille and inspect the transmission fluid cooler mounting bracket for a grommet behind the mounting bolt. See Figure 1 and Figure 2.
Inspection Result Service Action
Grommet present - No further action required
Grommet not present and transmission fluid cooler not leaking - Install transmission fluid cooler mounting bracket
Grommet not present and transmission fluid cooler leaking - Install new transmission fluid cooler.
actions:
INSPECTION
Grommet present No further action required
Grommet not present and transmission Install transmission fluid cooler mounting bracket
Grommet not present and transmission Install new transmission fluid cooler
fluid
May 24, 2011 | Ford Escape Cars & Trucks
TV has has lamp and thermal sensor replaced since purchased in 2006. Now the TV comes on then shuts off after about 30 seconds and the red light on the front panel stays on. It will not turn back on as...
That is the problem with the new sets the bugs haven't been worked out . The analog sets last longer ,more reliable and have been debugged over decades of time. It sounds like another thermal sensor ,because what is happening is once it cools off you can turn it back on. Try and move it out from the wall or a place where air circulates around it,that should help, This time when the thermal sensor gets replaced tell the guy to put a heat sink on the component to keep it cool.
Mar 30, 2011 | Televison & Video
Rheem Power Vent model RN 21-VP40-1 gas water heater no hot water but venting runs. Is it the ignitor or the thermostqat? About 10-12 years old.
it may be the thermal coupling that is bad for the pilot light. if it goes bad the flame will go out. replace thermal coupling. so if the pilot light is out then it will not heat water. or turn burner on.
Oct 28, 2010 | Rheem Water Heaters
We have Westinghouse apartment size fridges - some of them are making a very audible knocking sound when the compressers turns off. This does not happen in all the suites - we have 36 fridges. Thanks for...
Hi. Thisis a really simple fix. The compressor grommets are worn just from normal use. The compressor torques during start and hammers the compressor base against the mount. Then when the unit shuts off it generates a reverse torque and the base moves hammering the grommet against the mount.
The grommets are changed by usually remvong the mouting pin clips lifting the compressor ONE foot / grommet change at a time and then slide the locking pins back in place.
Have someone look at the grommets or get 1 compressor number and then go to any appliance parts source and either order or purchase your needed grommets.
It is not an expensive fix and they could all be done in less than1 day if someone was diligent. The biggest time consumer here is the process of opening the lower back panel. I would however plan on de-linting / cleaning with a vacuum and brush EACH units condensor coils and fan (if installed.)
Again remove ONE grommet (example) order replacements locally at the appliance parts source and install them.
Kelly
Sep 20, 2010 | Westinghouse Refrigerators
Installation of grommet on model cwtf 15 ( 1 lwr/2 upr pf
Which grommet, there are several on the bunn models, but the most commonly replaced one is the one for the P. stat. Remove the top panel there are 2 screws one in front and one in back, then lift the top 2 burners off machine that will give you access to the tank.
Apr 30, 2010 | Bunn CWTF 15-2 (1 Top Warmer) Coffee Maker
Home Logo
315 people viewed this question
Top Jaclyn Love Home Experts
Donni Steen
Tom Chichester
Are you a Jaclyn Love Home Expert? Answer questions, earn points and help others
