Question about Rio S10 MP3 Player
Which MMC card is used in the Rio S10 MP3 Player
SK-S10 with MP3 and card....How do you get it to work?....Is there an opp's manuel?
As I understand, SK-S10 is a Bluetooth speaker. If your MP3 player is not Bluetooth-enabled (and I believe very few are), you cannot use the SK-S10 with the MP3 player. But you can use it (via Bluetooth) with your cellphone, tablet, computer (if Bluetooth-enabled) and with any other Bluetooth-enabled media device.
Nov 17, 2014 | Audio Players & Recorders
BATTERY FOR A RIO CARBON (5GB ) mp3 pLAYER
1. look on ebay for battery if anybody would sell one.
2. go to walmart look in the flash drive isle for a sandisk ultra 2 cf card 8gb about 40$ .
3. open the rio and take out the old hard drive and then find a pc to format the cf card with a cf card reader make sure to format with windows 7 in my computer and choose quick format select default allocation size and then hit start.
4. when succesfully formatted put cf drive in rio carbon.
5. then put back plate back on carbon.
6. then look here for rio carbon developers firmware
http://en.wikipedia.org/wiki/Rio_Carbon
7. go to bottom of wikipedia page and click 3.04 Download link 1 and download the exe program and then run as administrater load up the firmware and then walla you have a working mp3 player again.
Sep 03, 2012 | Rio Carbon MP3 Player
I NEED A driver
did you google any other sites than rio that provide a driver if so see if that helps and good luck
Jun 19, 2012 | Rio S10 MP3 Player
I need a USB Cable for Rio S10 MP3.
  • Hope this helps and thank you for using FixYa.
Regards. Tony
Jul 20, 2011 | Rio S10 MP3 Player
Pearl rio carbon mp3 player 5gig
The microdrive is probably broken. Some people have claimed that if you give the sides a sharp tap then it has worked again but if this doesn't work then you probably require a new player. I have managed to replace the microdrive with a CF card in my Rio carbon, this has worked for many people may not work for you (you can read this: Replace broken hard drive with CF card if you want to try)
Hope this helps,
Mowcius
Oct 31, 2008 | Rio Carbon MP3 Player
MMC memory card does not work
It might just be the type of card. I put a SD card in mine and it works fine.
Dec 11, 2007 | Rio Forge Sport Digital Media Player
Using an external memory card
you should format the Sd card by the software from rio, and I am using 1g SDcard ,I am not sure if 2g sd card works fine.
Jul 31, 2007 | Rio Sport S35S MP3 Player
Rio s10
? Verify that the USB cable is securely inserted into the USB port on both the Rio Carbon and your computer. ? Connect the USB cable to a USB port on the back of your computer rather than to a USB port on the front of your computer. ? If using a USB hub, connect to a powered USB hub. Unpowered USB hubs may not work. ? Remove USB extension cables from the connection path. ? Disconnect other USB devices. ? Both Windows XP Service Pack 1 (SP1) (or greater) and Windows Media Player 10 (WMP10) must be installed for your computer to detect a Rio Carbon set in MTP mode. ? If you do not want to install SP1 (or greater) and WMP10 on your computer you should disconnect the Rio Carbon and change the Transfer Mode setting to MSC mode. Good Luck
May 24, 2007 | Rio S10 MP3 Player
Rio s10 usb cable
Take it to the nearest computer accesory store (radio shack, and ask them for a cable for it... they are plentiful (my mp3 cord works on my Razor cellphone)
Mar 25, 2007 | Rio S10 MP3 Player
Rio S10 MP3 Player Logo
20 people viewed this question
Top Rio Audio Players & Recorders Experts
isaac johny
isaac johny
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
