Question about Pyle Pldnv78i 7-inch Double Din Touchscreen Lcd Monitor With
App destroy-ic And it freezes
  • Jennifer
    Jennifer May 16, 2014
    Did you ever figure this one out? I'm struggling with this one myself and have no idea what's the solution.
App Destroy-IC popped up and car stereo-tv hanged! Anyone knows how to fix this one?
What is the brand name of this set. It is not clear by this shot. Only 'SON' can be seen. You haven't either said about it too. If you wish to get some details; check the site linked here. Pull up older posts.
Sep 30, 2016 | Televison & Video
My android 4.4 kitkat tablet freezes when apps are updating.Is there aything I can do?
In your settings for the google app store you can change it to require you to authorize any app being updated. that way you can skip the ones you don't care about, or all of them, to avoid them problem.
Nov 04, 2014 | Tablets & eReaders
Marantz sr5007 receiver dead after lightning strike
Hi Ridgep.
Replacement of the TOP258MG IC Should resolve your problem. Make sure you have fully discharged all the caps on the primary side of the power supply before fitting your replacement IC as they are very easily destroyed during installation.
May 08, 2014 | Marantz SR5007
Phone keeps freezing
> Check the number of applications that are running in the back ground close some and check if it still freezes
> Try to identify from when the phone started freezing - if there was an app you downloaded prior to that uninstall that app and check if still freezes
> you can also install an anti virus and run a scan to check if your phone is infected
Oct 23, 2013 | Vodafone Cell Phones
Mobile " phone freeze "
Hi, it should be possible to solve Phone freeze on Fastgsm.com. Just select your phone model, I hope it's supported.
Apr 21, 2013 | Cell Phones
Trransistor by five legs had destroyed i want
That 5-leg component is an IC, more likely to be switch mode power supply IC. What is the make and model of this product? What is this product? Pictures will help a lot.
http://s807.photobucket.com/home/budm/allalbums
Apr 27, 2010 | HP mx705 17" CRT Monitor
104s philips monitor
Why do you suspect the horizontal or vert curcuits? I would suspect the HV curcuit since no display at all. Gary(Honkity Hank)
Sep 18, 2007 | Philips Standard 104SLE 14 in. CRT Monitor
Tv cuts off 10 seconds after switch on and destroying vertical output ic
If the main IC is not putting out a vertical drive signal then the vertical output will not do anything and therefore will not be damaged. What exactly do you mean by the set "literally eats deflection IC's"? What is the number on the vertical output IC? I will bet that your pump-up cap or pump-up diode is defective.
Jul 03, 2007 | Sharp 27K-S100 TV
Pyle Pldnv78i 7-inch Double Din Touchscreen Lcd Monitor With Logo
310 people viewed this question
Top Pyle Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Tom Chichester
joel maureal
Are you a Pyle Computer and Internet Expert? Answer questions, earn points and help others
