Question about Musso Stainless Steel Pola Ice Cream Maker
Musso shaft not turning - Musso Stainless Steel Pola Ice Cream Maker
My musso ice cream maker is making a knocking sound when on. Once ice cream starts to freeze it can't turn it any more. Loose belt? How do I fix or take apart? Thank you!
I would look at the motor itself. You will have to remove the cover and see what is happening. What I would be looking for is a loose motor mount or a missing/broken off mounting bolt.
Feb 20, 2015 | Musso Ice Cream Makers
Need new cover for lello musso pola desert maker
Contact the manufacturer they should help or put you on to someone that can.
Oct 27, 2013 | Lello Musso Pola 5030 Desert Maker
I have a Musso L2 or L2A ice cream maker. I am searching for a service manual with a list of replacement parts.
Suleiman, your directions are not clear -- how do I "wiggle off the mixer blade assembly before the bowl"? I can't get that central spindle to budge no matter how I tap it or wiggle it or pull it or try to unscrew it. I can't take the top off the machine to get at the switch housing inside. Please, can you post a video of how to take apart a Musso Stella ice cream machine?
Sep 19, 2013 | Musso Ice Cream Makers
Problem with 2 Musso Pola Machines
Depending on the ingredients, it could take 40 minutes to make a batch. Make sure you mixture is very cold before it goes into the unit by chilling in the coldest part of the refrigerator until very cold. If anything less than a very cold mixture goes into the unit, the freezing time will be quite long. The outside of the unit will not feel cold, just the inner wall of the bowl. Also, if your recipe includes any alcohol, this will inhibit the freezing process.
Mar 15, 2010 | Musso Stainless Steel Pola Ice Cream Maker
CAN ANYONE PLEASE HELP ME OR EXPLAIN WHY MY MUSSO ICE CREAM MACHINE TAKES HOURS TO CHURN 1.5L OF CHILLED MIX. DAVE 07 5448 2937
Do you use enough salt to assist in the freezing period? What kind of salt do you use? Use rock salt since it works better than table salt. This wills speed up the freezng time.
Nov 06, 2009 | Musso Stainless Steel Pola Ice Cream Maker
Need manual for musso 4080 lussino desert maker
I cannot find a manual, but if you go this website you will get info on your machine and tons of ice cream ideas to use with your Musso machine. http://www.makeicecream.com/muslusicecre.html
Jun 11, 2009 | Musso Lussino Dessert Maker 4080 1.5 Quart...
I need to buy a new Ice cream well/ bowl
go to Http://www.catering-machines.com they have full list of spares or parts for Musso stella.
All parts for the musso ice cream machine including lid, motors, gear wheels, gearbox, musso paddle Musso serial numbers start L1 = Musso piccolo L2 = Musso stella L3 = Musso Club L4 = MUSSO CONSUL.
Apr 29, 2009 | Musso Stainless Steel Pola Ice Cream Maker
Musso Switch
Mar 18, 2008 | Musso Stainless Steel Pola Ice Cream Maker
Musso Ice cream maker freezes and then heats up during use
Jan 14, 2008 | Musso Stainless Steel Pola Ice Cream Maker
Musso gelato maker where can i buy parts
Oct 31, 2007 | Musso Stainless Steel Pola Ice Cream Maker
Musso Stainless Steel Pola Ice Cream Maker Logo
116 people viewed this question
Top Musso Ice Cream Makers Experts
ray gallant
Ruth summersides
Are you a Musso Ice Cream Maker Expert? Answer questions, earn points and help others
