Question about Viking 27" Professional Select Built-in Electric Double Wall Oven - VEDO127
Digital clock needs to be replaced on Viking double oven (part PE050214). How do I remove the top panel to replace it?
  • 3 Answers
SOURCE: viking oven won't turn on
I had same problem (twice) with my Viking dual fuel range. In my case a relay that supplies power to the oven heating elements failed. The convection fan would run. The elements were warm to the touch. If you have a free standing range, it may be that relay (part number PM010026) which is located in the front of the stove. Remove a long narrow stainless steel panel (1 screw each side) located under where the door hinges. You can hear the relay click when you turn up the oven thermostat. That will help you locate the relay.
Note: Viking does not sell parts. You have to find their parts distributor for your part of the country.
Posted on Mar 05, 2008
barkencoa
  • 3463 Answers
SOURCE: Viking Double Electric Oven VEDO127T
Probably a faulty heater element, some ovens have more than one element in the compartment, so it is possible you only have part heat.
Posted on Dec 02, 2008
  • 5 Answers
SOURCE: I have electric double oven VEDO275SS by Viking
you need to have a new thermostat fitted or the old one re callibrated if possible
Posted on May 29, 2009
  • 162 Answers
SOURCE: wehre is model number located on viking oven?
It is usually on the stove at the bottom of the oven door. you might have to remove it to read it properly
Posted on Sep 18, 2009
  • 832 Answers
SOURCE: Viking double ovens. Can both ovens be cleaned at
Unplug your oven, and clean both at once., Yes, you can.
Posted on Sep 26, 2009
Viking double oven control panel labels rubbed off
The control panel face can be ordered from Viking Range unless the unit is very old, then I would suggest partstown.com, You will need the model and serial number from the rating plate on the unit. These parts are usually not very expensive and are really easy to replace.
Hope this helps....GOD BLESS...Randy...
Feb 02, 2012 | Viking Designer DEDO130 Dual Double Oven
I have a Viking double wall oven model DEDO130. I have terrible baking results in the upper and lower. Mostly burning the tops (pizza, biscuits, etc) while the centers aren't done. A tech from the...
Home > Cooking Parts > Wall Oven Parts > Control Panel Area > Oven Thermostats >
G50012998 DESO SERIES T/STAT KIT Viking Electronic Part. ALL SALES ARE FINAL.
Viking Thermostat Replacement Kit
btn_emailafriend.gif pbox_border_left_top.gif clear1x1.gif pbox_border_right_top.gif clear1x1.gif G50012998 DESO SERIES T/STAT KIT Viking
List Price: $189.14
Our Price: $133.83
You save $55.31!
Return Policy Electronic Part. ALL SALES ARE FINAL.
Availability:: Usually Ships in 1 to 2 Business Days Subject to Stock Availability - Call to be sure.
Product Code: G50012998
The part is not that hard to replace. but it is expensive. In my opinion it should correct your problem since you have that much difference.
clear1x1.gif pbox_border_left_bottom.gif clear1x1.gif pbox_border_right_bottom.gif
Jun 08, 2011 | Ovens
I used the self cleaning for the top oven of my double whirpool Accubake ovens today. It worked fine during the process. But now, after it has cooled down. The panel is not lit up with the clock etc. and I...
There is a non-resettable fuse on the back of the oven that will have to be replaced. The oven will have to be removed from the wall and the back panel removed from the oven to access the fuse.
Nov 22, 2009 | Whirlpool RBD305PD Electric Double Oven
The digital and analog timer do not work
No, there is not a fuse on this model. You will need to repalce the clock assembly for this unit. Call us asap and we'll ship the correct part out to you asap so you can start cooking again. We look forward to working with you!
Oct 17, 2009 | Viking DEDO205 Stainless Steel Electric...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
NEED HELP ON DCS WO-230 DOUBLE OVEN
there are 2 screws at the top outside and 2 or 3 on the bottom of the display panel. remove those and the panel should lift off the mount. remove the ribbon cable and 4 screws for the display and replace.
Oct 05, 2008 | DCS WO-230 Electric Double Oven
Viking oven won't turn on
Sep 20, 2007 | Viking DEDO205 Stainless Steel Electric...
Open Questions:
See all Viking 27" Professional Select Built-in Electric Questions
Viking 27" Professional Select Built-in Electric Double Wall Oven - VEDO127 Logo
53 people viewed this question
Top Viking Ovens Experts
Dan Webster
Dan Webster
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Viking Oven Expert? Answer questions, earn points and help others
