Question about Scunci SS1000 Handheld Steam Cleaner
Trigger is broken - Scunci SS1000 Handheld Steam Cleaner
Why does my sprayer spray without me holding trigger
Valve in the trigger not returning or the o ring broken ------ fit new trigger.
Sep 25, 2016 | Vacuums
The hand grip of my Hoover FH50026 does not work. I press the handle grip, but no liquid goes out
It may be the trigger inside the handle is broken. The trigger pushes a rod that goes down to the valve at the bottom of the fresh water tank to allow the water to flow out.
Feb 16, 2015 | Hoover Vacuums
How do I repair a non-functioning solution trigger
The trigger has tabs on each side that snap into slots in the handle so that the trigger pivots in the slots. The slots where the trigger pivots may have broken, if so the trigger will not push the valve open and allow the water flow. If the tabs are broken you will need to replace the upper handle. If you supply me with your model number I will determine the proper part for your model.
Dec 14, 2014 | Hoover SteamVac F5914-900 SpinScrub...
My hoover steamvac trigger won't spray
Remover the upper handle assembly and check the linkage (inside the upper handle) where it connects to the button/trigger assembly in the handle grip. This may have detached or the trigger may be loose from its mount in the handle. Reattach or replace the broken part.
Sep 03, 2014 | Hoover V1 SteamVac SpinScrub Vacuum
My Hoover Two Tank carpet cleaner still dispenses cleaning fluid...but only if I keep my thumb down on the 'extra solution' trigger. The main (and much easier to use) trigger doesn't work anymore. I'm...
The main trigger might have broken. This is common if the trigger is pulled too hard. You can take the handle apart on most units and replace the trigger. Usually the broken spot is where the trigger pivots.
Oct 29, 2013 | Vacuums
Broken trigger on dc31
I had the same problem where the trigger doesn't always work (it works if I turn the unit upside down). I've since worked out it's the battery contacts which just needs a bit of a clean. It works now no matter which way I'm holding it.
Sep 20, 2012 | Dyson DC31 Animal Bagless Handheld...
The machine turns on and the indicator seems to be spinning but the water is not moving.
Operating the trigger does not dispense water into the spinning brushes - is that the problem?
If so, remove the clean water tank and look in the opening behind the black grommet that seal the water tank. Operate the trigger and look to ensure that the valve is operating (moves downward when trigger is pulled). If it does not move, the trigger shaft is stuck or broken and will need to be repaired.
Nov 21, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I think the trigger on my upholstery hose is broke how can i tell? trigger is loose- water just flows out and i have to shut the machine off. i have a hoover steam vac dual deep cleaner
The most common issue with this is the white nozzle tip broken. sometimes it comes out. it still could be the trigger. take it to a shop and they can tell right away. the trigger is spring loaded, you should feel tension.
Oct 09, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Cleaning solution tank dumping
in some cases the reservoir that the tank sits on would have to be replaced. best way to tell is, if you take the tank off and pour a little water in the valve where the rubber gramet is. if it holds the water its good, but if it goes down without you pressing the trigger then it will be the reservoir.
Jul 27, 2009 | Hoover F5906-900 Upright Steam Vacuum
Scunci SS1000 Handheld Steam Cleaner Logo
22 people viewed this question
Top Scunci Vacuums Experts
JoeVacs
Tom Chichester
Are you a Scunci Vacuum Expert? Answer questions, earn points and help others
