Question about Nihon Kohden Cardiofax Q Ecg-9130k
How to set time and dat on Nihon Kohden ECG-9130k
Time is wrong
Is there a problem with model number PM2240? My pacemaker tells me I'm in AF all the time, but other tests like ECG and Holter monitor, show nothing is wrong!
When you're dealing with the heart, I don't think you should rely on any suggestions or opinions from 'fixya' You should definitely consult your Doctor or a professional in the cardiac field. Please !!
Oct 25, 2017 | Ecg Medical
With manythanks,can someone mail the user manual or handbook for nihon kohden ecaps 12.
Sorry no mailed copies available. Is nihon kohden ecaps 12 a cell phone like your title suggests?
Feb 14, 2015 | Cell Phones
I have a Mortara ECG machine that I need to take back to factory settings and remove all preprogrammed persistent forms. Any ideas?
Hey Bro,
First, tell me what model of MORTARA ECG are you referring to. I work with different models of MORTARA ECG for some times. Maybe I can help you.
Jul 17, 2012 | Medical
Instruction manual for Nihon Kohden Model: EKG-1250A
HI Cheryl,
I have the instuction manual of Nihon Kohden Model: EKG-1250A with me in pdf format. If you can provide your email id the i will sent you the manual. Or you can contact me in my email id aajingopakumar@gmail.com . I will sent you the manual as replay. Its not possible to upload the manual through fixya as it is in pdf format.
Ajin
May 29, 2012 | Medical
How do I set the date and time on my GE Mac 15 Interpretive ECG Unit?
http://www.frankshospitalworkshop.com/equipment/documents/ecg/user_manuals/Marquette%20MAC%2015%20ECG%20-%20User%20manual.pdf
Page 12-3 or 201 in Adobe Reader has info for setting up date and time
Mar 23, 2012 | Ge Medical Systems Ge Healthcare Mac 1200...
How does ECG machine find that signals are good for printing (in auto mode)? some ECG machines take up to 20 second time for printing start
hi,
When the at2 is in auto mode, first of all it check the leads are properly connected or not.Then it will acquire the ECG and store the same in its memory then only it starts printing. that's why it takes that much time to give a printout. When its starts printing you can remove the connections from the patient because it have already memorized the ECG.
If interpretation is in on position it will compare the acquired ecg with the standards in its memory (allready programed by the manufacturer). and will give a detailed report with ecg.
ok
Feb 04, 2011 | Schiller Welch Allyn Cardiovit At 2...
As i turned on the monitor the screen shows CMOS WRONG PRESS F1 TO SETUP PRESS F2 TO LAOD DEFAULT VALUE
hi,
first of all check the main battery back of ur machine by unplugging from the mains power supply. if machine shuts off, then u have to replace the battery.and then set the date time etc by pressing F1. and then save it and exit set up. next it will not ask for F1 or F2.
if the main back up battery is ok, then another possibility is the CMOS backup battery of ur machine have some problem. that's why it loosed all the seted parameters. then u have to replace the CMOS battery of ur machine. normally 3V battery. then set the date time etc by pressing F1. and then save it and exit set up. next it will not ask for F1 or F2.
ok
Jan 13, 2011 | Dmm UT4000F Multi-Parameter Patient...
I have installed CHT editor software in my HTC HD2 around 1month ago.. It is working fine 4 me... Today i enabled the phone security code (simple pin) and also unlocked it many times b4 problem...
i have installed CHT editor software in my HTC HD2 around 1month ago..
It is working fine 4 me... Today i enabled the phone security code (simple pin) and also unlocked it many times b4 problem occurs..
bt after dat i switched off my phn n nw its demanding the security code which i entered d same with which i opened it many times...bt every time it is showing me wrong password... is there any solution 4 dat... i m pretty much sure dat i m entering d right password..
my mobile model is HTC HD2 T-mobile Leo, i bought it from USA n unlocked it in india...
Nov 24, 2010 | HTC HD2 Smartphone
GE MAC 5000 with a printer problem
You are probally using the wrong paper. Look at the part number for the paper you are using and cross refrence that with the correct number.
Mar 24, 2009 | Ge Medical Systems Medical
Omron Portable Ecg Ekg accuracy problem
Hello Josh. You will need a EKG simulator. I suggest you contact your local community (junior) college electronics class or a local Bio Medical services in your local hospital. When locating one kindly walk in and ask very nicely with the portable in hand if you my perform a operational test for you on benefit.
Aug 27, 2008 | Omron Portable Ecg Ekg Handheld Hcg 801...
Nihon Kohden Cardiofax Q Ecg-9130k Logo
97 people viewed this question
Top Nihon Kohden Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Nihon Kohden Health and Beauty Expert? Answer questions, earn points and help others
