Question about Solar Welding Tools
My solar 2114 wire feed welder quit working.the black wire from power cord goes into rectifire then out to center terminal on switch . should there be continuity.between black poer cord wire and black switch wire.. if it does have does this mean rectifire is bad. and if so are they available
CarlGehrke
  • 169 Answers
SOURCE: Wire feed not working Miller 250 mig welder
If the knob spins all the way around (and especially of it didn't always do that), it's broken. This could mean that the nut that holds the rheostat in place has come loose, or it could be that the wiper inside the rheostat has broken off the shaft. To find the voltage measurements, correct schematics, etc, I'd need to know the serial number of your welder.
Regards,
Carl
Posted on Feb 23, 2009
  • 9 Answers
SOURCE: Wire does not feed on MIG welder
my lincoln mig welder did the same exact thing!! I thought what you did, drive motor bad. But it wasn't, on mine there is a reset/breaker button, it's like a 25 amp fuse that can be reset, it was bad! so I took the 2 wires that went in and out of it and jumped them together (not advised) to see if it would work then. BINGO!! now I have to find replacement. Look inside for a fuse or some thing like that.
hope this helps, oh yeah, when I ask the mechanic at the welding store he said that drive motors rarely go bad!!
Hawk
Posted on Apr 10, 2009
SOURCE: NO WIRE FEED BUT WELDER CLICKING AS IF FEEDING
This could be caused by not enough pressure on the drive wheel. Try adjusting pressure as spelled out in you manual.
co7196
  • 3433 Answers
SOURCE: snap on ya219B mig welder. when welding, spark
Is your ground good?
Posted on Jul 06, 2009
  • 71 Answers
SOURCE: I have a solar meg welder 2-175.The feed motor for
try changing the fuse if it has one
Posted on Aug 08, 2009
Have a solar 2160 wire feed welder but do not seem to have any heat control.can't weld sheet metal,just way to hot.
The capacitor(s) may be open. or resistor has failed. It is also possible heat selector is fused to the one setting.
Nov 20, 2012 | Welding Tools
Tip
How to change your dryer from 3 wire to a 4 wire power cord. (short and simple)
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
on May 23, 2009 | GE DBSR453EBWW Electric Dryer
Replacing electrical cord
if you buy a color coded cord and plug then red and black go on thee 2 outer terminals of the power terminal and the white wire goes between these as this is the neutral connection and if it has a green ground wire connect this anywhere to the metal case of the unit, if its a gray cord with no colors then the 2 outer wire on the cord go to the outer terminals on the units power terminal block and the center wire on this cord goes to the center terminal on the unit
Jul 28, 2012 | Roper REX4634KQ Electric Dryer
Where do the wires go for the power cord in the rear of the dryer? there is no color code.
If you are using a 4 prong cord,the white goes to the center terminal and the green to the external ground screw.
Black and red go to the right and left terminals. Does not matter if right or left..
A 3 wire cord...the center wire goes to the center terminal. The other 2 go right and left terminals.
Jul 13, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Was welding and welder quit acking wire feed and gas still work i have a century pro wire welder model 170gs
Check earth wire has not become dislodged,
Pop the cover and check for burnt terminals, often overheating of the transformer can cook a terminal, easily cleaned up and replaced.
Mar 31, 2010 | Welding Tools
Need help with the wiring on the reddy heater 110 btu
CIRCUIT CARD-
-Photocell blue wired go to two terminals marked BLUE PHOTOCELL (any order)
-Motor red wire plugs onto terminal marked MTR MAIN, motor white wire plugs into terminal marked WHITE MOTOR.
-potentiometer (thing with knob) two white wires plug into terminals marked TEMP SEL
-Black wire from switch to terminal marked L1 BLACK
-White wire from power cord goes to terminal marked N White
-Ignitor (used to be yellow wires) goto terminals marked IGNITOR and IGNITOR RET (any order)
OTHER-
-White wire from power cord goes to switch terminal marked 3A , other pigtail of the white wire goes to board as described above.
-Black wire from power cord goes to swtich terminal marked 4B
Nov 14, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
I have a 30 amp conversion cord with 4 wires and 3 terminals. What wire goes where?
Oct 04, 2009 | Hotpoint TDC32 Electric Dryer
I have an old maytag electric dryer model #DE608 that has a three wire cord. I moved into a new home with a four hole dryer outlet. Can I switch the dryer electrical line from the existing three wire to a...
Jul 06, 2009 | Dryers
GE Dryer not producing heat
First, replace the door switch. Second, check the wiring of the new cord. It should be as follows:
Third, if you still have no heat, make sure there is strong air flow out the vent outside the house when the dryer is running. If all that is good, check for 240 volts to dryer. (dryers can run the motor on 120, but need 240 to heat). Comment back (including model number) if you have further questions.
May 22, 2009 | LG DLE7177 Dryer
4 prong power cord to a 3 prong monunt I'm trying to replace a 3prong cord with a 4 prong but there is an extra wire, what do I do with it?
May 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
Welding Tools Logo
51 people viewed this question
Top Solar Welding Tools Experts
Bill Boyd
Are you a Solar Welding Tool Expert? Answer questions, earn points and help others
