Question about Dell Computers & Internet
Exiting broadcom pxe rom how do i reboot - Dell Computers & Internet
4 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: PXE-E61: MEDIA TEST FAILURE, CHECK CABLE
The PXE-X61 error means that the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
Posted on May 14, 2009
  • 6 Answers
SOURCE: prablon may loptop
I think you hard drives failed. When the hard drive fails, the boot tries to find another way to boot up, so if the boot sequence lan is enabled, it will try to boot from the lan port (in your case broadcom pxe), when it can't boot from here either, it exits (exiting broadcom pxe). Replace your hard drive and re-install windows.
Posted on Oct 14, 2010
  • 107 Answers
SOURCE: PXE-E61 Media test fail, PXE-MOF Exiting Broadcom PXE ROM
Disable PXE in the Boot Sequence in the BIOS setup [F2]
Posted on Aug 10, 2012
I have a fiujitsu hard drive in my acer aspire 5315 my keyboard has no keys just some rubber tips and when i turn on its says broadcom UNDI PXE-2.1 v10. 0. 9 copyright yada yada and then it says: PXE-E61:...
The keyboard needs replacing. Replacement keyboard for your laptop maybe available from this WEB site.
PXE-E61 ERROR
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Dec 18, 2012 | Computers & Internet
Broadcom base code PXE-2.1 v1.1.0 Operating system not found
Go to your laptop's bios and select first boot device as your hard drive. and also disable the other boot devices and boot from network must be disabled. that's all.
Sep 22, 2012 | Acer Aspire 5536-5224 Notebook
Aug 10, 2012 | Dell Computers & Internet
Prablon may loptop pxe-mof exiting broadcom pxe rom .broadcom undi pxe-2.1 v14.0.8
Oct 14, 2010 | Computers & Internet
I have Dell Studio 1555, Vista but later intalled XP on drive D, I have problem my CD/DVD drive does not read the Data, CD does not revolve in high speed make the tak tak sound as it try to read bit after...
Your message indicates that Pxe Boot is enabled (boot from lan card), go to bios settings and from the list of first boot options, please select the hard disk (hdd) or Cd-rom as the first boot device, reboot your system and check whether this helps or not.
It is also necessary to disconnect and reconnect your dvd/cd rom's power cable and data cable.
If you don't know how to do, then just reset the bios settings to "load default" ...
Good luck.
Thanks for using FixYa.
Jun 24, 2010 | Computers & Internet
Broadcom UNDI PXE 2.1 v11 . 4.1 Copyright (C) 2000-2008 Broadcom Corporation Copyright (C) 1997-2000 Intel Corporation All rights reserved. Broadcom Base Code PXE- 2.1 v1.1.0 Copyright (C)...
This is showing because the computer is not seeing the hard drive that contains the operating system. In some cases this is because the hard drive has come dislodged from the interface on the motherboard. Dells are good for this because the hard drive slides into the side of some models. Try reseating the hard drive and reboot. Your worse case scenario is that your hard drive has failed. The reason you are seeing the PXE-MOF etc. is that the laptop ias now looking for a network hard drive to boot from. It can't find the intenal hard drive so it is searching for other means to boot.
Jun 16, 2010 | Acer Aspire 3690-2196 Notebook
Broadcom UNDI PXE-2.1 v11.0.11 Copyright (C)
change your boot priority. press power button then keep on tapping F1 key until your reached to setup utility. go to boot menu and set your boot priority 1 to your HDD. if compute wasnt able to detect your HDD . then there is a problem wth your HDD, you need to call you manufacturer for HDD replacement if unit is still under warranty
Mar 31, 2010 | Lenovo 3000 G530 Notebook
My aspire 5315 laptop is stuck on this sceen, broadcom undi pxe 2.1 v10.0.9 copyright (c) 2000-2006 broadcom coporation copyright (c) 1997-2000 intel corporation all right reserved. pxe-e61: media test...
Hello higgstwiligh,
The above message is mainly informational and doesn't necessarily indicate a problem. The acronym 'PXE' stands for Preboot Execution Environment. It's an environment to bootstrap computers using a network interface card. Usually the reboot is done by a remote computer on a LAN (Local rea Network). The Realtek NIC (Network Interface Card) somehow expected a PXE boot to be taking place when the computer was restarting. One solution is to restart the computer and go to the boot menu (F2 on some systems) and choose to boot from the master drive.
*Here's a link to a good article explaining what PXE is: http://www.search.com/reference/Preboot_Execution_Environment
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Nov 01, 2009 | Acer Aspire 5315 Notebook
Computers & Internet Logo
10 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
