Sleep mode on every ten min. .i did set times
    Scholar:
  • 56 Answers
Go to Control Panel (make sure you set drop-down box in upper right to 'View by: small icons', then choose 'Power Options'. In the left pane, click 'Choose when the computer sleeps', also while you are in there, make sure your Power Button setting is set to 'Shut down', NOT 'Go To Sleep'. Many are set this way from the factory and it can cause major performance issues down the road.
Posted on Feb 12, 2014
What is the sleep mode?
To know more about the sleep mode and its adjustment, refer its user manual. It is a mode that you can set the sleep time, after which the TV will turn Off when that time is reached; after 30 min, iHr, 2Hr or so, to which that time is set for. http://electrohelponline.blogspot.com/
Jul 06, 2014 | Proscan Televison & Video
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
Laptop screen goes off and then to sleep mode
go into your control panel and under power saving turn off the sleep mode settings also check power saving sleep mode settings in bios by pressing f2 at boot also check battery options in security settings hope this helps and yes hp techs are just high paid plumbers reading memos from screens so there not usually much help lol
Mar 01, 2013 | HP Pavilion Computers & Internet
My fax machine keeps going into sleep mode. How can I prevent this from happening?
you can't. you can only change the length of time before it enters sleep mode. (00-99 min). if you want to change, "menu/set" "1" "8" then enter the length in minutes from the dail pad, hit "menu/set" then "stop/exit".
razors
Dec 02, 2011 | Brother IntelliFax-4100e Fax
My phone goes into sleep mode every ten seconds. How do I turn off the sleep mode?
If by sleep mode you are referring to display shut down than it is simpe solution, you just go to Settings -> Display and under Screen timeout change a setting to whatever time you like ...
Aug 08, 2011 | Samsung Galaxy S GTI9000 Smartphone
Hello, my brand new (2 weeks) DELL 1545 laptop is going into hibernate/sleep mode, 10 times in the past 1 hour 1/2???? It is NOT shutting down, just have to turn the power button on and all is back to...
goto the control panel - power options and see what you have set there for sleep mode, under the powerplan - often it can be set on a couple of mins when using battery change the setting to longer
Sep 28, 2010 | Dell Inspiron 1545 Notebook
Does anyone know how to turn the sleep mode on for a Aficio MP4000 photocopier
you can do it by pressing the energy saver key it is next to the number " 3 "on the control panel or you can put a certain time when the machine will go to sleep.
1. press the [user tools] key it's on the right side under the copy key.
2. press [system settings] on the touch screen.
3. press [timer settings] on the touch screen.
the time can be set from 1-240 min.
it means after how much min. do the copier to go to sleep mode
Jan 13, 2009 | Ricoh 4506 Copier
Problems with zune
Check the menu settings and see if the sleep mode has been activated - turn off.
May 23, 2008 | Microsoft Zune JS8-00001 Digital Media...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
