Question about Nihon Kohden Cardiofax Q Ecg-9130k
Set the date and time
Hoe to set date and time
Setting time, date on power book g4
I'm taking it that you are running system 10 so go to system preferences under the apple menu, then go to date and time under System. Go to time zone and allow the time zone to be set automatically and then go to date and time and set the date and time automatically. If you want to set the date yourself you can uncheck the set date and time automatically and then select the date and then the time using the up and down arrows. Hope this helps.
Dec 06, 2012 | Computers & Internet
I bought a Delstar netbook yesterday at the flea market but every time I try to sign in it gives me a certificate Error, hoe can I fix this problem.
Hi there!
You normally get this certificate error if the time and date on your computer is incorrect. Check the time and date on the lower right corner and see if it is correct. If it is not, then just update it so you won't get the certificate error.
Hope this helps.
Thanks
Apr 10, 2011 | Computers & Internet
Dont know hoe to set the coreect time and date
Thank you for contacting FixYa.
ANALOG
  • Locate the knob on the side.
  • Pull the knob out. The second hand should stop ticking.
  • Twist the knob clockwise until the correct time is displayed on the watch face.
  • Push the knob back in, and the the second hand will resume ticking.
  • Digital Watch
  • Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right sidePress the "Date Advance" button on the upper right side. This will reset the seconds.
  • Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
  • Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
  • Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
  • When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your setting.
  • Best regards. Jewel
    Sep 13, 2010 | Watches
    Setting the time and date
    To set the date, make sure that you are in Rate Set. type in the date such as August 3, 2010 would be entered as 08.03.2010 then press the date time key. This will set the date. To set the time type in the time such as 4:20 PM would be entered as 16.20 then press the date time key and this will set the time.
    Feb 02, 2010 | Sharp EL-1197PIII Calculator
    Current time and date samsung tocco lite
    On the main menu select Settings, then Time & Date.
    Set Time zone updating to Manual.
    Then SCROLL down i.e. drag the menu upwards (this is the bit that many don't realise.)
    Then you will be able to set the time & date.
    Sep 20, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
    How do i set the time on my nokia 2630
    Select Menu > Settings > Date and time. Select Date and time settings to set the date and time. Select Date and time format settings to set the formats for date and time. Select Auto-update of date & time (network service) to set the phone to update the time and date automatically according to the current time zone. Hope it helped...
    Aug 05, 2009 | Nokia 2630 Cellular Phone
    Date Settings
    Hi there and thanks for coming to FixYa.
    To put the date and time stamp on the images do this:
    1) Set the Mode dial to Setup.
    2) Hit the Up arrow on the control button to Camera and hit the right arrow on the control button.
    3) Select Date and Time with by hitting up or down arrow on the control button then press right on the control button.
    4) Hit the conrol button up or down to select Date and Time, then press the center of the control button.
    5) Return the Mode dial to the camera postion to start taking pictures.
    Rob
    Feb 28, 2009 | Sony Cameras
    How do you set the date on an LG KS360
    http://www.o2.co.uk/deviceinfo/device-pdfs/lgks360eng.pdf
    Manual
    Hope it helps.
    Most cell phones get the info from the provider based on your triangulation.
    It is in the Settings Menu.
    Under DATE & TIME
    More detailed Instructions....
    Changing your date & time
    You can set functions relating to the date
    and time.
    1 Press Menu or and select Settings.
    2 Select Date & Time and choose from the
    list below:
    Set date - You can enter the current date.
    Date format - You can set the date format.
    (YYYY/MM/DD, DD/MM/YYYY, MM/DD/YYYY)
    Set time - You can enter the current time.
    Time format - You can set the time format to
    either 24 hours or 12 hours.
    Auto update - Select On, the phone will
    automatically update the date and time.
    Jan 03, 2009 | Cell Phones
    Time and date stamp add to camera
    Do a search for photo time date software. Irfanview does have that ability and it is free.
    Aug 02, 2008 | Olympus FE-210 Digital Camera
    Canon MP11DX
    press the date/time button
    press and hold the = button
    once blinking set the date
    press the = button again
    once blinking set the time
    the "x" button changes A / P
    press the + button again
    Feb 29, 2008 | Canon LS-100TS Calculator
    Nihon Kohden Cardiofax Q Ecg-9130k Logo
    57 people viewed this question
    Top Nihon Kohden Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Nihon Kohden Health and Beauty Expert? Answer questions, earn points and help others
