Question about 1991 Ford F150 Truck Front Power Window Regulator with Motor Driver
Replace a heater core in a 1991 ford f150
Heater core
    Genius:
  • AM Auto Parts Master
  • 2,494 Answers
Remove heater box from under dash,remove hoses ,the heater core is inside the casing.
Posted on Mar 31, 2016
Coolant leak at firewall (outside) on 1991 4.9 F150. Comes out at the bottom of the housing mounted to the firewall.
If hoses seem Ok and the clap is tight it may be the Heater Core has sprung a leak, although is leaking outside maybe the line where the hose attaches has a leak.
Oct 29, 2013 | 1991 Ford F150
Heater will not get hot
does the engine run at normal temp
if not the thermostat is stuck open replace it
if it runs at normal temp your heater core is clogged needs to be replaced
give me feed back how it works for you
Jan 22, 2011 | 1991 Ford F150
1991 ford f-150 blowing work but no heat change water pump cap flush out heater core next tell me what will work?
Check and adjust or replace the blend door cable also make sure blend door moves fairly easy
Aug 31, 2010 | 1991 Ford F150
In my 1991 F150 (186,000 imles)I have a strong glychol smell that is comming from my HVAC system - the only thing I can think of is a leak in the heater core, but I nothing dripping to the ground. Could...
Your nose and suspicions are probably correct. If you start to notice a film on the inside of your windshield while driving at night its definately your heater core pushing antifreeze through your defrost vents. I don't suggest trying any additives. Those quick fixes have sent more vehicles to the junk yard than I'd like to think about.
Feb 20, 2010 | 1991 Ford F150
I need a diagram on how to put a heater core on a 1991 ford f150 v6 thanks
Get on Google and download the diagram some are free
Feb 06, 2010 | 1991 Ford F150
Replace heater core
Disconnect heater core hoses. Remove glove box assembly. Remove the 8mm screws holding the cover on over the heater core. There may be a module in front of the cover. Move module out of way. Carefully disconnect heater control cable. The heater core should come out .
Jan 22, 2010 | 1991 Ford F150
97 ford f150 4.6 the pipe that gos to heater core hose is leaking. is this pipe pressed in? thanks
The inlet/outlet pipes (tubing) is an integral part of the heater core. If the actual core is leaking, you 'll need to remove and replace or repair the heater core. Be sure it's not the hose that is failing ... alot easier and cheaper to change out a hose and clamps...
Nov 20, 2009 | 1997 Ford F150 Regular Cab
How to change the heater core in a 1991 ford f150
remove the glovebox and there should be a cover for the heater core there is five or six screws that hold it on remove the heater hoses and pull the heater core out
Jul 18, 2009 | 1991 Ford F150
1991 Ford F150 Truck Front Power Window Regulator with Motor Driver Logo
19 people viewed this question
Top AM Auto Parts Vehicle Parts & Accessories Experts
geo marin
terry stevens
ray gallant
Are you an AM Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
