Question about Frigidaire PL30DD50EC 30" Downdraft Ventilation System with 500 CFM
Frigidaire downdraft won't stay closed
After using the vent, I press the button to retract it back into the countertop. The unit retracts, and then comes right back up.
2 Suggested Answers
SOURCE: frigidaire dryer faqe7001lw blinking lights
Try resetting the computer like a cars e.c.m. by turning the dryer on and plugging it from the outlet. It worked for me once w our new Malta front loaders
Posted on Apr 07, 2012
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
Kenmore retractable vent keeps randonly going up and down , sometimes for 6-7 times before it will stop.How do we fix it?
I hope you have the $400 appliance insurance. I had the same problem in a new house purchase. First the downdraft wouldnt work, and then wouldnt stop.
It was a micro switch and motherboard issue. Took four visits by the (insurance paid for) techie to get and fit the right part. Good luck
Mar 08, 2014 | Kenmore 36" Telescopic Downdraft Range...
I have a Kenmore Vacuum cleaner 116.24212. The retractable electric cord won't retract. How can I fix it?
The retraction mechanizm is likely jammed. Mostly likely the cord has jumped it's groove in the retraction wheel/hub. If you are good with tools there is a 70% chance you can get it to work again with a basic DCR operation. Most mechanical problems can be solved using this simple rule: Dissassemble Clean and Reassemble.
CAUTION: The retract mech has a powerful spring inside, avoid exposing. Most retract mech units are rivoted closed so consumers won't poke thier eye out.
CAUTION: UNPLUG THE UNIT
Open the unit from the bottom and the top lid of the canister should come off.
The retract mech should be obvious as it is where the cord comes into the unit.
Look for the cord being bound by iteslf either on top or underneath (lie two cordes in one groove)
Remove any binding.
If you see no debris or obsticals for the cord to retract (where it is getting stuck)
Your spring could have sprung!
Do you feel and retract at all?
Can you locate the releae mechagnism?
Does the Release button seem to function? When Pressed it should take pressure off of the cord hub.
The retract mech may need replaced. Overall the cost will be about $60 for parts.
Feb 12, 2011 | Vacuums
Kitchen Aid downdraft hood stuck in retracted position
The filters need to be seated properly to complete an electrical safety circuit. This keeps the unit from operating without the filters. The best way I have found to fix them when they get dislodged in the closed position is by using two spatulas. The first is used to move the filter forward a bit and the second is used to keep it pushed tightly forward to complete the circuit.
Apr 03, 2010 | KitchenAid KIRD861HSS Kitchen Hood
My viking downdraft vent isn't working. I didn't
The halogen light have all gone out (3) is there a fuse and is it hard to find or replace
Dec 20, 2009 | Viking Kitchen Ranges
Downdraft vent won't stay down. Push the button and it retracts normally, then pops right back up?
check your bottom limit switch - i'm guessing its bad. the unit doesn't stop operating til it trips a (working) limit switch, if the switch is bad it'll cyle right past it and go back up until it hits the top limit switch (again).
Aug 27, 2009 | KitchenAid KIRD861HSS Kitchen Hood
Pivot arm in telescoping downdraft system sticks when closing
Having the same problem. Unit worked well for 1 1/2 years and then suddenly it dropped after I was thru using it and pushed the arrow for it to go down after it dropped the power wouldn't turn off - had to unplug it.. Repairman came out , took it out, lubricated it , re-installed and next time it went up fine, vented fine but when it went down it dropped again and power wouldn't turn off again. I am hesitant to call him out again unless I can figure out what else might fix the problem. I have noticed that the top piece now seems to be bowed a bit. I guess I can have him take out the cooktop but think there must be enough room for it if it worked fine for the 1 1/2 years. It is a soapstone countertop.
Dec 28, 2008 | GE Profile JVB67 36" Telescopic Downdraft...
My 7 1/2 year old Thermador CVS36RB Cook 'n' Vent won't retract
sears labor is 137 plus parts. that is something that would need to be looked at. it could be a few different things. if he is handy he can open it up to see if anything is misaligned or broken. the vent may even just be a little crooked and once straight may go up and down like normal
Nov 22, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Screen retracts, then opens, and retracts, and does not stop
I had that problem too I'll I did was press the reset butoon on my unit and everything resetted but the bypass code, you have to reprogram your stations and the time thats it
Mar 20, 2008 | Jensen's VM9312 Car DVD Player
Kitchenaid downdraft retractable vent
Your drive motor arm is not making contact with either of the two limit switches at 6 and 12 positions. Your arm may be loose, gear stripped, broken bracket. Turn off the power at the breaker panel and remove the vent pipe cover box (4 nuts) see what is going on inside. Tellstar
Mar 01, 2008 | KitchenAid KHTU165RSS Stainless Steel...
Frigidaire PL30DD50EC 30" Downdraft Ventilation System with 500 CFM Logo
69 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
