Question about Microsoft Windows XP Home Edition
Noise whistling whistling noise from windows in house
    Novelist:
    Scholar:
  • 131 Answers
If the noise is a high pitched hum first make sure it is coming from the PC rather than some other device. Just turn everything off except the computer (including turning off the monitor) and see if the noise goes away. Now if you still hear the noise, turn things back on and turn the pc off for about 30 minutes. Then turn it back on. If the whistle is not present at the start but takes a bit to start -- a minute or two or more -- it is probably heat related. If it is immediate, it is probably due to some hardware failing.
If it's a heat problem and you can, turn the system off, remove the side of the computer and run it that way. If the problem goes away (and stays away) then take a can of compressed air and blow out all the dust and dirt you see in the box (again, turn it off when you do this) close it back up and test. If it doesn't go away, the problem may be more serious, needing attention by a qualified technician (to at least change the heat compound on the CPU and other places).
If the whistle is immediate and you are comfortable with it, put your finger in the center of each of the spinning fans to temporarily stop them. Stop them only for a second, not for more. If the whistle stops have that fan replaced. Finally, if the whistle is almost immediately apparent when you start the system then it is usually coming from the either the power supply or the hard drive. A replacement power supply should cost about $40. In most systems they are easy to change so it may be something you could do yourself. We charge $49.50 for the labor, just to give you a rough idea. If changing the power supply doesn't do the trick it's probably the hard drive. So back up your stuff and take it in to be redone....Hard Drives are generally around $70 and labor to redo the system $100.
Posted on Mar 06, 2014
Making whistle noise on off on run and stopping.
There are basically two types of whistle noises.
* Whistle when you get more gas (increase RPM, put gas pedal, sometimes just idling but louder when you put more gas)
This usually intake-side leak.
Intake manifold itself, intake manifold gasket (most likely), even airfilter housing, Airflow meter housing (connector), anything where air goes to engine.
usually engine get rough or unstable idle when intake leak occur.
Engine knocking or pinging may feel.
* Whistle when you decrease RPM (engine brake, reduce speed, sometimes just idling but louder when it dropping RPM)
This usually Vacuum-side leak.
There are many vacuum hoses in engine room. even inside of cabin (heater control, etc)
Try to spot where it coming from.
Vacuum also connected to Brake servo, heater control and spark timing.
Put metal or plastic pipe (small PVC pipe will work fine) to one of your ear then isolate source of noise and find where it come from.
Feb 26, 2016 | Cars & Trucks
Loud whistling noise it is just going on five years old when I pull it backward a loud noise emmits
If you whistling is only happening when pulling back on the machine, the problem is with the connection between the bag housing and the swivel neck. There is a rubber gasket between the two, located on the bottom of the bag housing. Check to see if this seal is in place. If it is there and in good shape, check for excessive wear on either the swivel neck or bag housing. Windsor Sensor Vacuum Seal 5163 86144910 allstar javelin
Apr 02, 2014 | Windsor Vacuums
Whistling sound coming from right rear
Checking Window Seals - The window seals (weather stripping) in your car are used to seal the water and wind for entering the passenger compartment. When these seals fail from damage or are eroded by the weather they can allow wind noise to enter the passenger compartment. This failure can cause a whistling noise as the car is driven. Some noises are only present when the vehicle is driven at certain speeds such as 55 MPH. These whistling noises can be difficult to find since you are driving at the time. Have a passenger help with the diagnosis by running their hand along the area the noise is being generated from. Once the noise source has been located replace or repair the failed seal and recheck.
Dec 11, 2013 | 2004 Ford Taurus
Toyota avalon window whistling starts at 40mph
Take it to the dealer...they will fix it...for free - under warranty!
GL,
Td
Oct 06, 2012 | 2012 Toyota Avalon Base Sedan 3.5L V6...
My vax vacuum has started making a high-pitched whining/whisting noise
Ususally this is caused by a forein object has gotten hung in the suction impeller attached to the motor. the noise flucuates due to the housing flexes with the movement of the handle and rod. the housings are usually made of plastic and something very small can easily get stuck in it and stay for a very long time. The vacuum needs disassembled and the forien object removed from the fan housing...
Hope this helps
Sincerely
Roger
Feb 07, 2012 | Vacuums
S40 t5, check engine , whistling sound
Read my other posts to the same problem. if the noise goes away with the oil filler cap removed you need to replace the oil filter housing and hose. good luk
Jul 08, 2009 | 2005 Volvo S40
Loud whistling noise when travelling at higher speeds (ie above 50mph)
I had a problem with a whistling car after 50 mph and it turned out to be the front window gasket. I put silicone on the trim and problem solved.
May 10, 2009 | 2003 Toyota Tacoma
WHISTLING BELOW TURBO
Its surely not turbo, its is somewhere a hole or leak in turbo air filter housing or air inlet pipe that is making noises when turbo sucks air. check the air pipes wheather they are fitted correctly. Take a keen look at air hose and close any hole with silver tape check the hose is fitted correctly in Turbo air filter housing (if not then it makes whistling noise when air is being sucked by turbo) . Clean all air filters and then give it a go.
May 07, 2009 | Peugeot Liberte Cars & Trucks
WHISTLING NOISE-DAY AND NIGHT REFRIGERATOR MODEL # GSS201BPDWW
Pull the cover off to the fan and compressor housing and clean it. Clean coiling as well. Most coils are located under the unit. They make an appliance brush to reach between the coils that can be purchased at an appliance store.
Apr 18, 2009 | GE DBSR453EBWW Electric Dryer
Microsoft Windows XP Home Edition Logo
43 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
