Question about Electronics - Others
Repair transcend v60
My transcend device is not working.i need that device can u please share me how to recovery it and woring its as Normal
    Sergeant:
  • 376 Answers
You can try using a file recovery software like Bad Copy Pro 4.10.125 or any similiar software. If successful, you should probably reformat it using the fat32 file system.
Posted on Jun 22, 2014
4 Suggested Answers
SOURCE: Windows 98 SE Driver for Transcend Jet Flash V60 8GB #TS8GJFV60
hi, i srinivas, i am using dual booting of win 98 & windows xp operating systems. when i am using my transcend pendrive in win xp which is easily working, but in win 98, how can we install perpect drivers for my transcend pendrive.
so please give the solution to solve my problem.
Posted on Sep 13, 2008
Geekman
  • 32281 Answers
SOURCE: Transcend JetFlash V60 16 GB Pen Drive not working properly
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that its Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32.
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Posted on Oct 05, 2009
bronk50
  • 27725 Answers
SOURCE: transcend 32gb jf v60 pen drive not working
If now you can see your usb drive there might not be any need to do the following
Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
then you might have restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
Transcend jetflash recovery
JetFlash Online Recovery is an advanced new software tool specifically developed for Transcend JetFlash USB flash drives.
If your flash drive is not working properly, in most cases it can be repaired instantly by using the recovery tool's simple user-friendly interface.
The JetFlash Online Recovery Tool is conveniently located on the Internet, so no matter where you go, you can service your flash drive 24 hours a day, 7 days a week.
All data on your JetFlash drive will be permanently erased during the repair process.
Please backup the contents of your JetFlash before proceeding.
This software is designed to repair malfunctioning JetFlash USB flash drives.
It will not recover
any data/pictures stored on the device.
Hardware Requirements: USB Port (supports USB2.0), Internet Connection
System Requirements:
Windows XP SP2/ 2000 SP4 or later version(Administrator rights required)
Windows Vista (Administrator rights required, must turn off UAC) To turn off UAC in
Windows Vista, please go to Control Panel > User Account -> Turn User Account Control on or off > and then uncheck ''Use User Account Control to help protect your computer.'' Please remember to restart your PC for the new settings to take effect.
Windows 7 (Administrator rights required, must turn off UAC)
To turn off UAC in Windows 7, please go to
Control Panel -> User Accounts -> Change User Account Control Settings -> change to "Never notify" -> then, Please remember to restart your PC for the new settings to take effect.
Download Links
JetFlash Online Recovery (for Windows 2000 SP4/ XP SP2/ Vista /7)
JetFlash Online Recovery (Only for V15; for Windows 2000 SP4/ XP SP2/ Vista /7)
JetFlash Online Recovery (Only for JF620; for Windows 2000 SP4/ XP SP2/ Vista /7)
User Manuals for JetFlash Online Recovery
Manuals (Traditional Chinese)
Manuals (English)
If you need more help with this post a reply
Transcend have a lifetime warranty
Hope this helps.
Posted on Nov 28, 2012
My Dell Centrino laptop does not recognize the device: Transcend 16 GB JF V60 Pen Drive, what can I do?
Hi Anonymous,
There is a possibility that the flash drive might have failed. Try using the Flash drive on a different computer and if the same works then you may have to download drivers as suggested by Steve Butterworth.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Jun 28, 2015 | Dell Computers & Internet
Transcend 32gb jf v60 pen drive not working
restore defaults
In XP
It will not recover
Download Links
Manuals (English)
Hope this helps.
Nov 27, 2012 | Electronics - Others
My 32 gb transcend pendrive not work how to repair what is problem and where in pune
You have to be the computers Administrator to change any values on any hardware on a computer
Click start control panel user accounts on the users tab click the name of the computer Administrator you must have full control.
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
If you are running a Windows XP OS then you might be able to:
click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver
restore defaults
In XP
It will not recover
Download Links
Manuals (English)
Hope this helps.
Nov 26, 2012 | Electronics - Others
Transcend 8GB JF V60 now failiure to function. Message shows computer has malfunctioned, and windows does not recognize it
The memory chip inside your transcend has died. This is unfixable , the memory stick is dead, junk it and get a new one.
Jun 16, 2011 | Computers & Internet
Hi, I have two pen drive of transcend one 4 GB JF V10 , another 4 GB JF V60. These are not detected by computer.
These drives should not require drivers for WINXP or WIN7. Make sure your USB port is working by trying a known good pen drive, and see if it is detected.
If you are using WIN98, they may require a driver, even though the transcend website says that they do not.
Try rebooting your PC and insert your pendrive as soon as startup is completed.
For additional help, go to the transcend website:
http://www.transcendusa.com/Support/DLCenter/index.asp?LangNo=0&ItemID=TS4GJFV10&axn=SRH1_RLT&DLKeyWd=JFV10
and on the bottom of the page is a drive recovery tool that you can install and try. Please be advised that the recovery tool WILL erase anything on your drive!
Finally, if you have used your drives for copying files from a different operating system (MAC or a different version of Windows), its format may not be compatible with your PC.
Jan 30, 2011 | Computers & Internet
Oct 05, 2009 | Electronics - Others
My Transcend JetFlash V10 16GB USB
Go to the transcend site. In the support section, click drivers/downloads. Type in your model number or search for it. Mine was a Transcend 4GB JetFlash V10 drive. So the model number was TS4GJFV10. There will be a download called Recovery Tool. Get it. Run it. That's it.
P.S: use the global download link, its faster.
-TheIVth
Oct 11, 2008 | Computers & Internet
Jul 13, 2008 | Electronics - Others
Electronics - Others Logo
46 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
