Question about Yamaha RX-V530 Receiver
Can't change input mode
Hi, I have a Yamaha RX-V530rds. It has 3 optical inputs. D-TV/CBL, DVD and MD/CD-R. But I can only change the input mode from the DVD input, between auto, dts and analog. When I plug in my PS3, TV or Apple TV in to DVD input with auto input mode, everything works fine. Now I would like to plug in all three devices, in the three inputs, but this doesn't work, because I can't change the input mode from the other two inputs. Not even with only one device. Can someone help? Thanks and sorry for the english ;) Andre
  • Andre Ptsch
    Andre Ptsch Feb 13, 2014
    Fixed it, by resetting the receiver.
  • Andre Ptsch
    Solved it, by resetting the receiver.
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
Marcos_Ce
  • 71 Answers
SOURCE: DTV Cable No Sound
Check if DTV/CBL is set receive COAXIAL or OPTICAL inputs. Good luck
Posted on Nov 23, 2008
smarthome2
  • 1114 Answers
SOURCE: I've lost all digital sound to my reciever.
Get into the cable box menu and look for audio settings, chances are your digital output from the cable box is off. If you still can't get audio, reply with your Cable Box Make & Model and I can help you further. Hope this helps
Posted on May 25, 2009
dunnbiker
  • 8546 Answers
SOURCE: Unable to assign optical and digital inputs to other inputs
It won't let you assign the same input twice. Check to see that DVD is not already assigned to any other In(x) function.
From the manual:
• You cannot select a specific item more than once.
• You cannot assign the same input source to both “IN (2)” and
“IN (3)”. For example, you assign “CD” to “IN (2)”, “–––”
appears in “IN (3)”.
Posted on Mar 16, 2010
dunnbiker
  • 8546 Answers
SOURCE: Hi. I write from spain. I have the blu-ray LG
Have you tried the another optical cable? They don't tolerate dirty connections or small-radius bends in their routing. THAT (and the expense of optical cables) is why I always choose coaxial connections when possible.
Posted on Mar 02, 2011
I am unable to surround when I have XBOX and Blueray via 2xHDMI and 2xOptical, I am only able to get 1 device to work at a time, pleast help
This is normal. You cannot run 2 optical inputs at the same time. You can only use one or the other. For example . . if you are playing your xbox, you would use that corrosponding optical. When you are done and whant to watch your blue ray, you would have to change inputs to that corresponding optical.
May 10, 2012 | Yamaha RX-V365 5 Channels Receiver
Mar 02, 2011 | Yamaha RX-V363 Receiver
I can't get a sound from my yamaha rx-v367. my tv is lg le5310
Last update: 05/02/2008
Connect the audio outputs jacks from the TV to any available audio input terminals on the Yamaha receiver, other than the phono input. You can use any analog audio Left (White) and Right (Red) inputs on your receiver such as the DTV/CBL, SAT or VCR input. There are no special settings needed on the receiver, other than selecting the correct input. There may be some settings that will need to be changed on the TV. Consult the TV ownersEmanual for setting up the TV to output audio to an external source. If youre TV has a digital output (Optical or Coaxial) it can also be run to one of the digital inputs on the Yamaha receiver, such as DTV/CBL or DVD. There may be some settings that will need to be changed on your TV. As always, consult the TV ownersEmanual for setting up the TV to output digital audio to an external source.
NOTE: When the source of the audio signal is coming from an HDMI device connected to the TV, the TV may not output in 5.1 surround sound.
Jan 01, 2011 | Yamaha RXV367 Receiver
Hi yes i have the jvc RX-8030v and i have a issue with the digital audio in! My dvd toshiba RD-KX50 player does not have a digital coaxil out it only has digital optical out! But on the back of the jvc...
Read you manual, there is a page with a matrix of the audio in selectiosn that can be made for coaxial and optical on each input. Then you have to go into setting button on the right side of the unit and the "push set" knob to change the inputs for the digital audio.
My problem is, I had this all working and went to change the inputs around to add a optical DVD changer and now niether of my optical inputs are working any more. Analog is still fine.
Nov 21, 2010 | JVC RX-8030V Receiver
From the manual:
Mar 16, 2010 | Yamaha RX-V363 Receiver
I want the tv sound to go through my yamaha rx-v363 receiver
You can do a couple of things depending on your unspecified TV and/or cable box:
For vanilla TV stereo (at best) audio: if the TV has RCA audio out jacks, run them to DTV/CBL or TV input.
For cable box (potentially multichannel) audio, if your cable box has a digital coaxial or optical audio out, run it to one of the digital in's on the receiver.
Jan 24, 2010 | Yamaha RX-V463 Receiver
Sound from tuner but no other devices
The RX-V365 cannot process audio from the HDMI cables (you will still be able to hear it on your TV), you will need to run a seperate coaxial or optical cable into the audio input for the relevant component on the back of the RX-V365.
Dec 26, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
I have two Component Video products (DVD and Cable Receiver) plugged in but can't get the DVD to work. How do I switch from one to the other? This is for a Yamaha RX=V550
Inputs on your receiver are assignable. Assign one input to DVD function and other input to DTV/CBL for example. Refer to page 49 of your manual for instructions.
Dec 05, 2009 | Yamaha RX-V550 Receiver
No audio input from video modes
First of all, there is no audio information on the video lines. These are typically used together with the audio lines to complete the interface between the source(TV, DVD,VCR,etc) and your receiver...accordianman
Jul 02, 2006 | Yamaha RX-V630 Receiver
Yamaha RX-V530 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
