Question about Lindhaus PB12E-QDCW 12" Heavy Duty Power Nozzle w/Quick Central Vacuum
Pb12e will not run
Powe head will not run
I have a Lindhaus powerhead MOD.PB12e SN123463. The powerhead turns on and the roller starts turning but after a couple of seconds it starts sounding like something is not letting the roller turn properly...
A common problem is for hair to get wrapped around and forced into the end bearings which causes the motor to work harder or drive belt to slip. Cleaning the hair out can be a short term fix but new bearings might be needed. It's also a good idea to replace the drive belt at the same time as the slipping belt is probably not going to perform well even with new bearings.
Mar 03, 2015 | Lindhaus Vacuums
Fully charged no power
Could be a jam/blockage in the Power Head. To check, remove the Power Head and extension tube and try again. If the cleaner runs normally without the Power Head attached, then the problem is obviously in the Power Head. First step - remove the brush from the Power Head and check for jam/blockage. The rectangular hole directly behind the brush (through which the dust passes on it's way up the extension tube to the top of the cleaner) is relatively small and clogs easily (especially if you have a pet!), so you need to make sure that it is clear. If the cleaner doesn't run with the Power Head removed, then it is probably a problem with the main motor and would need more expert investigation!
Mar 29, 2014 | Dyson DC35 Handheld Vacuum
Shark steam mop not sending steam to attachment
It sounds like the head could be clogged up. Try running water in the head and see if that works
Jun 07, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
We have a kenmore canister vacuum and it runs but when turn on the rug clener brush the brush will not run we then put on small brush head and that will work
If the power head motor runs, but the brush doesn't turn, then the belt is broken. Replace the belt and it should work.
Nov 29, 2010 | Kenmore Vacuums
Need manual for bissel powe steamer brush select
User Manuals can be downloaded from the Bissell website
Feb 07, 2010 | Vacuums
My rainbow vaccum will not turn on
If you have a power head with it, try the head as well. If the power head runs the problem is your motor , possibly carbon brushes, if the head will not start the issue is either your switch or the cord, inspect the plug end for signs of strain.
Sep 05, 2009 | Vacuums
Power cut off after handle was dropped on floor while vacuuming
connections inside the handle came loose. happens to me all the time. take the handle apart and connect the wires back.
May 16, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Access to panasonic mc e450 electrical supply panel
Disconnect powe
Remove three screws
Tap base of handle from front - it will then slide back
remove handle
Pivot bottom of cover over electrical box up and it will unclip from the top edge.
Sep 06, 2008 | Hoover Vacuums
Lindhaus PB12E-QDCW 12" Heavy Duty Power Nozzle w/Quick Central Vacuum Logo
Top Lindhaus Vacuums Experts
JoeVacs
Are you a Lindhaus Vacuum Expert? Answer questions, earn points and help others
