Question about Radio Shack Televison & Video
Put tv av mode without
When you push tv button red indicator will not stay on to reprogram. Have reprogrammed many times. Remote# 15-2113
    Top Expert:
  • Radio Shack Master
  • 74,136 Answers
To select its inputs, you should have its original remote control. No universal remote can go with this function. Gopakumar Gopalan Google
Posted on Feb 12, 2014
  • The Knight
    The Knight Feb 12, 2014
night71
  • 328 Answers
SOURCE: proscan universal remote
Find the manual here:
http://www.directv.com/learn/pdf/System_Manuals/RCA/RCA_DRD430RG.pdf
Hope that helps.
Posted on Oct 28, 2007
robotek
  • 1512 Answers
SOURCE: need to reprogram remote
Hi all
You can download the codes for GE remotes from here
regards
robotek
Posted on May 08, 2008
ktkodama
  • 37 Answers
SOURCE: Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Posted on Jan 20, 2009
SOURCE: how reprogram my universal rca remote control
hold the tv button down and keep it down and then press and hold the power button down and hold them both until the power button stays red then let go of both buttons then keep pressing the power button until the tv turns off and as soon as it turns off press the stop button and it should work.
Posted on Sep 30, 2009
  • 374 Answers
SOURCE: i have reprogrammed my dish remote to my tv but
Press menu -menu on the receiver. You should be able to see the remote address for the receiver. It will typically be set to 1 if it reset somehow but whatever the case make note of this number. Take the remote and hold the SAT button until all lights across the top illuminate. Now key in the two digit address- single digit numbers are preceded by a 0. Now press the pound sign in the lower right of the remote and observe that the SAT button flashes thrice. Now press the record button a few time to ensure it is locked. Now try exiting the menu screen with the remote.
If this does not work check the antenna on the back of the receiver and put it in the full vertical position and try again. If this fails you may need a new remote.
Thanks for using for using Fix Ya.
Ihope this resolves your issue.
Posted on Dec 21, 2009
Reprogram the URC-9910 universal remote for VIZIO E3D420VX
Universal remote code to check with Vizio TV is [0081.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. If you want to get more details and codes to different remote controls, check this.
Dec 30, 2012 | One For All URC-9910 LCD Remote Control
Reprogram toshiba se-ro329 remote
Aug 11, 2012 | Televison & Video
How to reporgram my tV's remote to the Tv again
Direct Code Entry
Code Search
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jun 09, 2012 | RCA Televison & Video
My universal rf10 shows empty. how can I reprogram it
Direct Code Entry
Apr 08, 2012 | Televison & Video
Program toshiba tv remote ct-885
Direct Code Entry
    Code Search Method
    Codes to Check:
    013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178
    0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
Mar 31, 2012 | Toshiba CT-847 Remote Control
Cant reprogram remote to tv
Direct Code Entry
Mar 16, 2012 | Televison & Video
Reprograming
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 20, 2008 | Philips Televison & Video
Please help!
Hope this helps :)
Jun 06, 2008 | Philips Televison & Video
Manual
Hope this helps :)
Jun 01, 2008 | Philips Magnavox Learning Universal Remote
I changed batteries in my remote and i cant figure out how to reprogram it
Hope this helps :)
May 13, 2008 | Philips Universal PH301S Remote Control
Televison & Video Logo
65 people viewed this question
Top Radio Shack Televison & Video Experts
Computer Repairing
Computer Repairing
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
