Question about GPX D1816 DVD Player
Says Bad Disk
After you put a DVD in it says loading then then says bad disk. Not very old or played that much and had no abuse. Tried cleaning DVD to make sure that that was not the problem
  • dipndap Feb 16, 2008
    JUST BOUGHT TODAY. SAYS "LOADING" ,THEN SAYS "BAD DISC". TRIED SEVERAL ALMOST NEW DISC AND A COUPLE OF NEW DISC ALL WITH SAME RESULTS.
  • priv8I Mar 13, 2009
    Same thing... dvd player is not very old and I have not used it very often, but when disc is inserted, you can hear that it is trying to spin, and then the words "bad disc" appears on the screen... please help!
I WENT BACK LATER, ROTATED THE DISC ABOUT HALF A TURN AND IT LOADED. TOOK IT OUT PUT ANOTHER IN AND IT LOADED JUST FINE ALSO. MAYBE IT WILL KEEP WORKING OK.
Posted on Feb 16, 2008
SOURCE:
When I put a dvd in it says "loading" for a good
Try cleaning the laser lens. Either opening the unit and cleaning with a cotton bud, or try a lens cleaning disk.
Oct 24, 2011 | Televison & Video
My dvd won't play. every dvd i put in, it says bad disc. the vcr works fine. is it time for a new system. i tried a head cleaner and it says bad disc
Not necessarily time for a new one. I would give the DVD player a good cleaning before you consider a new unit. A good cleaning disk with some little bristles on it. Run it through three full times. DVD players are far more sensitive than VCRs and have to be cleaned even two weeks or so. When they get real dirty it can take some fooling with to get the DVD player to even accept the cleaning disk. But if it just won't accept the cleaning disk and you can't watch a DVD in it then it's time for a new one. I had a DVD player one time that took an hour of fooling around with before it got cleaned good enough to play DVDs. Worked for a couple years afterward.
Regards, Tony
Apr 19, 2011 | GoVideo Go Video DVD/VCR Combo
When I load a disk I get 'Read', then 'No disk'. I have tried several commercial disks, and have tried with each side up. I have looked into the disk slot and cannot see anything which might have been...
If u can't play many of the DVD discs from Hollywood movies,Useally the disc itself the problems or the DVD recorder laser eye it bad.Tries websites like Amazon.com,Ebay.com buy a DVD cleaning kit.Put the disc in follow the directions,clean the laser eye data reader.50/50 chances will solved the disc not reading problems.If not the Laser eye is problems the unit not worth fixing buy a new one.DVD players are not woth the fixing of the Tech. prices.
Dec 15, 2010 | Panasonic DMR-E30 DVD Recorder
Whenever i put a disk in my mxt dvd player it loads and just comes up with no cd.
You said disk. If you have tried different dvd movies then I would suspect a dirty or weak laser. If it plays dvd's ok but wont play certain cd's then I would suspect a compatability issue. You can try one of those laser cleaners at most dept stores or if you take it apart (with it unplugged) the laser is located where you put the disk in and it has a small plastic lens you can clean with a q-tip and alcohol. If that doesnt help the laser is probably bad, depending on the player it would probably be cheaper to purchase a new player.
Oct 17, 2010 | Televison & Video
My CyberHome DVD 300 says "bad disk" every time I load a dvd.
pls check ur dvd player optial pickup lense.try to clean or replace.
Dec 28, 2009 | Cyberhome CH-DVD 300 DVD Player
Toshiba sd-4990 dvd player will not load a disk
Your toshiba is not spinning that's why it keeps on saying loading. Unplug the dvd Open the device,once open plugin the dvd and put the dvd cleaner in the player. take your finger on the top where the dvd disk is and spin the disk. What happening is that you are cleaning the len. keep spinning until it spin on its own.Put the toshiba top back on and clean again. It should clean on it's on. Now you can play your dvd. Clean your dvd on a regular basic.
Mar 12, 2009 | Televison & Video
Bad disk
Trata poniendo un disco limpiador de laser.
Mar 25, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD will not load/format new disk
I have got exactly the same problem. Thought I had found some discs that worked as the first one formatted, since then all have come up with that crappy error protection message. Samsung really should sort this out.
Mar 25, 2008 | Samsung DVD-VR330 VCR and DVD Recorder
Bad playback
have same problem, get dvd error message "disc error unable to read disc
Oct 03, 2007 | Samsung DVD-V1000 DVD Player/VCR
Wait!! this units not that old??? if it isent dont touch the mechanism try calling 1-800-samsung and see if they will repair it for you for free??. good luck
Apr 10, 2006 | Samsung DVD-VR320 DVD Recorder/VCR
GPX D1816 DVD Player Logo
518 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Damen Wong
Damen Wong
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
