Question about Dough Pro DoughPro SL1577 20" Smooth Split-Top Panini Grill
Bottom of press not heating - Dough Pro DoughPro SL1577 20" Smooth Split-Top Panini Grill
No steam coming throwc
Normally when water is put inside steam irons, it get stored in tank then if thermostat knob is set for steam then water moves to bottom heated portion of iron. Water converts to steam as base plate is hot, heated steam comes out through perforated holes. If holes are blocked due to scale formation steam flow is blocked. The descaling has to be done as per instructions given on descaling wax manufacturer. sometimes if water does not enter through a rubber washer that is water tank to heated bottom portion then also steam will not get generated hence no steam. Please check above points and identify the problem.
Jan 08, 2015 | Irons
Good day I have an euro pro iron and it leaks all the time leaving water on washed clothes.also it leaks out of the bottom??
The water may come out at the bottom instead of steam. this is due to insufficient heat produced. So switch on your ironbox and keep it in full temperature using the knob. then the water will be coming out as steam and not as water itself. Try again.
I hope this is useful to you
Thanks
Jun 27, 2010 | Sunbeam Euro Press 4045 Iron
The iron is on but the bottom is not hot why? every thing else is working but not the the part where you would press with and now we have no iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Sep 29, 2009 | Euro-Pro Shark GI490 Iron
Singer steam press csp-1 iron
heatman101
Mar 03, 2009 | Singer Electronic Steam Press Iron
Need electric cord for heat press
I just aquired the same iron-- do you have the manual? I was told there was a place to add water and am unable to figure that out.
Jan 19, 2009 | Irons
Cleaning Ironing Steam Press
If it is not teflon coated sand it of with 400 grit sand paper. sand from front to back and it will create a nice grain and
this paper is so fine it will not scratch the surface. Sand it gently until the substance is completely gone. Do not do
this if it is teflon coated. Hope this helps you.
George
Jul 11, 2008 | Yamata PSP-990A Iron
Water shooting out bottom holes
This normally means that the iron is not heating up enough check that you have adjusted the temp so it is not as the water will either come out of the bottom when not hot enough to steam or when the jets get dirty and need cleaning.
Thanks J
Feb 12, 2008 | Euro-Pro Shark GI490 Iron
Irons will not heat properly
This may sound weird, but try them at someone else's house, it could be possible that your wiring is not allowing them the amperage they need to heat properly.
Nov 27, 2007 | Irons
Dough Pro DoughPro SL1577 20" Smooth Split-Top Panini Grill Logo
47 people viewed this question
Top Dough Pro Irons Experts
Are you a Dough Pro Iron Expert? Answer questions, earn points and help others
