Want to refill with liquid my e go cigarette whick part do i put the liquid in
After your battery has been charged, fill the clearomizer with your e liquid. Find a vape shop online that provides a wide variety of fantastic e liquid flavors to satisfy all tastes. So grab your favourite flavour and begin by unscrewing the clearomizer's metal part at the bottom. The coil is screwed into this portion, as you can see. Make sure this is securely fastened to the base. The three primary pieces of the clearomizer are seen on the right: the tank, coil, and base.
Squeeze your e-liquid into the tank while holding it upside-down and aiming it down the side. Make sure your juice doesn't get into the 'chimney,' a metal tube that runs down the middle of the tank. If you get liquid in here, it will almost certainly end up in your mouth (this is not dangerous but can be a little unpleasant). Also, make sure the tank isn't filled any higher than the top of the chimney.
You should probably contact the manufacturer.
You may also consider joining BecomeAnEX org Online Quit Smoking Support Network for peer support in quitting.
Become An EX Team
