Question about GE Lands Phones
GE 29488 Line 4 red light stays on
Changed the batteries and now an inactive line 4 light just stays on. How to I get it to turn off?
2 Suggested Answers
yalmer
  • 549 Answers
SOURCE: GE 29488
Note: Intercom features are NOT compatible when DSL is installed on line 1.You may need to reconfigure it for dsl internet if it is installed on line 1
Posted on May 27, 2008
Line 1 disconnects people on hold
Try these first and let me know
Intercom does not function correctly
• Make sure line 1 is connected properly and common to all phones on the system.
• Make sure all phone ID’s (station numbers) involved have been assigned.
Transfer does not function correctly
• Make sure receiver phones (stations) have same line connected.
Intercom indicator turns red and green alternately
• The station address needs to be re-assigned due to a duplicate station address in the system. See “Changing the Phone ID (Station Address)”.
Good luck,
Lee
Jun 17, 2008 | GE RCA 4-Line Speakerphone
What would cause the red light to stay on all the time. This is killing my batteries
Steve-
I have reviewed the on-line installation information for the DL2700 and I do not see your particular scenario listed (red LED staying on). Here is the website link:
www.alarmlock.com/
I therefore suggest that you call Alarm Lock (the manufacturer) directly with your problem for their assistance. The number is 1-800-252-5625. They are located in New York, so you will probably want to call during East-coast business hours. Be sure and have any model number and purchase date info on hand when you call.
Dec 14, 2011 | Trilogy Alarm Lock T2 TRILOGY® Digital...
Jayco camper has 6-plug connector------car has flat 4-plug connector where do green,yellow,brown and white wires from car flat 4-plug connector connect to on yellow, blue,brown,red,green and white wires...
It would be easiest, and best, if you were to upgrade the cars' trailer connector. The 4 way just supplies brake, parking, turnsignal, and a ground. The colors are the same on the 6 way, but 2 lines are added, usually for a electric brake controller and aux. circuit. Be careful about using the battery line (Red) on the 6 way connector unless you are also upgrading the white wire to a heavier gauge (at least the same size as red).
Green - Stop and Right Turn Signal (4/5/6/7 way)
Yellow - Stop and Left Turn Signal (4/5/6/7 way)
Brown - Running Lights (tail, side, tag) (4/5/6/7 way)
White - Ground / Negative (4/5/6/7)
Blue - Electric Brakes (5/6/7 way)
Red - Aux. charge line for emergency break away, battery charger, etc. (7 way)
Purple - Aux. backup lights / other purpose (7 way)
Aug 16, 2010 | Electronics - Others
How do I set up a ge universal remote control on a sony television Stopped working changed the batteries too.
Hi! For me to be able to give you the correct code for your universal remote control, I actually need the model number of your remote control because there are GE remote controls that need a 3digit code and there are GE remote controls that need a 4digit code. But since I don't have the model number you may just try these codes and the instructions below.
4 digit code for Sony are:
0128, 0013, 0002, 0071, 0380, 0152
3 digit code for Sony are:
002, 006, 013, 071, 128, 380
1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
2. Press and release the desired TV button. The red indicator blinks, then stays lit.
3. Enter the 4 digit code or 3 digit code from the list above.
Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
4. With your TV on, press ON/OFF. If the TV turns off, no further programming is required. Note: If some buttons do not operate your TV, try one of the other
codes.
Jun 14, 2010 | Televison & Video
GE 29488
May 27, 2008 | GE 29488GE2 Corded Phone
RCA executive series
No ringer could well be a setting and light on 2nd line means their is No 2nd line and most 2 to 4 lines phones at least require 2 active lines for the system to work correctly
Mar 30, 2008 | RCA 25202RE3 Corded Phone
Red light won't turn off ! ?
Your phone's keypad is damaged and you will have to get it replaced..
Oct 28, 2007 | GE 28031EE1 Cordless Phone
Hp laserjet 4 plus printer, message window "Ready", off line button shows red
You can try to do a "Cold reset"
turn off the printer hold down  the Menu/reset button and turn it back on.
Do you hear the machine go into rotation? the 4 plus has a high pitch sound follwed by the fuser turning ( you'll know when it does it) if it doesn't go into rotation then there is another problem.
Oct 13, 2007 | HP LaserJet 4 plus Printer
My intercom button flashed red to green. When I push a line button, I get a two-tone beep but no dial tone. I changed the internal 9 v battery. I unplugged the phone and waited, then plugged it back in....
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Aug 29, 2007 | GE 2-9450C Corded Phone
Lands Phones Logo
19 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
