Question about Canon Pixma Pro 9000 MARK II InkJet Photo Printer
The light on the cartridge printer does not turn on?
The green color cartridge has the problem
How do I slide the green toner tabs?
1. power down the printer.
2. remove all color cartridges from their slots.
3. inside the color slot, you will see a green slide that will not move until you pick up the plastic cover (it is the full length of the cartridge holder).
4. rotate the plastic cover forward.
5. slide the green slide 3 or 4 times. (DO NOT TOUCH SMALL WIRES!)
6. return slide to original position.
7. snap the plastic cover back in place
8. return each color cartridge to it's slot.
9. replace color cartridge holder back to printer.
10. close all covers
11. turn printer back on.
If you still get the "move green slide" error, just repeat these steps
This took me about 10 minutes for the process, after understanding what the "green slide" meant.
Apr 20, 2011 | Brother HL-4040CN Laser Printer
Tip
The green light is blinking constantly and the printer won't print
When the green lamp constantly blinking this mean one or both print head are defective.Here we can find which cartridge is defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
This printer can work with only one cartridge.If you don't use color printing just remove the color cartridge.
on Oct 26, 2009 | HP Deskjet 3845 InkJet Printer
Tip
Often happens HP cartridges to overheat.In that case the printer not recognize it and the green lamp blinking constantly.In most case only one of both cartridges defective and need to be replaced.But how to know which one?
Here's how: Open cover, put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
on Oct 21, 2009 | HP DeskJet 3745 Printer
Drum error. slide green tab in each color
3. inside the color slot, you will see a green slide that will not move until you pick up the plastic cover.
Oct 04, 2010 | Brother HL4040CN Laser Printer
The green power button blinks continuously and the printer will not print any type of job. The last job printed was very clear so I don't think I need a new ink cartridge. The status of the printer shows...
ya u need now inkjet cartridge or ur printers card dead 1st chack put black cartridge in ur printers and color cartridge out then see green light blinks if blinks black cartridge out and color cartridge put in the printers then u know thanls
Jul 03, 2010 | HP DeskJet 3940 InkJet Photo Printer
Green light working continously
It might be you change your cartridge to that and you did not insert it properly so that they blink. Try to check the cartridge if it can insert properly then restart your printer and try to print it again. If they are blinking again just press the reset button or turned off your printer then turned it on again and try to print.
May 29, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
ORANGE LIGHT IS BLINKING AND PRINTER WILL NOT PRINT
The Amber light is designated as the "Ink Error" light. With regards to a Hewlett Packard printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
If I have helped please rate my post...I will always do my best to help
Sep 11, 2009 | HP Laser Jet 1320 Printer
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
My x1240 scans but does not copy or print. What do you suggest?
You will need to do the following diagnostic tests to determine the exact cause of the error:
· Remove the ink cartridges
· Perform the self test (test B below)
· Test the ink cartridges
A. To remove the ink cartridges:
Switch the printer on by pressing the green button.
Open the front cover of the printer. The cartridge carrier should move to the center of the opening.
Remove both cartridges.
If the carrier does not move to the center of the opening, you will need to remove the cartridges by hand.
Turn the printer off and remove the power supply cable (the small circular one) from the back of the printer.
Inside the printer, locate the silver metal carrier bar on which the print carriage slides.
Locate the black rubber carrier belt above the carrier bar. This belt has tracks on its inner portion.
Grab the top portion of the belt and move it toward the right. As you move this, the ink cartridge carrier will move to the left. Continue to move the belt until the carrier is in the center of the opening.
Now pull both cartridges out.
B. To perform the self-test:
Disconnect both the power cable and the USB or parallel cable.
After one minute has passed, plug the power supply cable (the small black circular one) back in. (This step is necessary to reset the printer.)
Turn the printer off by pressing the green power button.
Hold down the grey paper feed button.
Turn the printer on by pressing the green button.
After the printer begins to feed paper, release the grey button.
Once the paper exits the printer, press the green button to turn the printer off.
If the power light blinks twelve times while no cartridges are installed, there is a problem with the printer. Please contact our Technical Support Centre for your service options. If this is a new purchase, you can also exchange the printer at the point of purchase. If the paper went through the printer as if printing was occurring, you will need to do some more testing. Continue as instructed below.
C. To test the ink cartridges:
Open the front cover and insert only the black ink cartridge. Make sure that you push it back until it snaps into place.
Close the front cover. If the light flashes twelve times, there may be a defect in the black cartridge. If not, proceed to the next step.
Turn the printer off using the green power button.
Hold down the grey paper-feed button.
Turn the printer on using the green button.
If the light flashes twelve times, there may be a defect in the black cartridge. If a page came through with a black line, your black cartridge is working properly.
Now you need to take the black cartridge out and perform the same steps with the color cartridge. If the light flashes twelve times, there may be a defect in the color cartridge. If a page came through with colored lines, your color cartridge is working properly.
If one of the cartridges is causing the problem, you will need to replace that cartridge. If it is a new cartridge, please exchange it at the point of purchase, or contact our Technical Support Centre.
IF u have problems u can use this link:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi
Mar 15, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark z53
You will need to do the following diagnostic tests to determine the exact cause of the error: · Remove the ink cartridges · Perform the self test (test B below) · Test the ink cartridges A. To remove the ink cartridges: Switch the printer on by pressing the green button. Open the front cover of the printer. The cartridge carrier should move to the center of the opening. Remove both cartridges. If the carrier does not move to the center of the opening, you will need to remove the cartridges by hand. Turn the printer off and remove the power supply cable (the small circular one) from the back of the printer. Open the front cover of the printer. Inside the printer, locate the silver metal carrier bar on which the print carriage slides. Locate the black rubber carrier belt above the carrier bar. This belt has tracks on its inner portion. Grab the top portion of the belt and move it toward the right. As you move this, the ink cartridge carrier will move to the left. Continue to move the belt until the carrier is in the center of the opening. Now pull both cartridges out. B. To perform the self-test: Disconnect both the power cable and the USB or parallel cable. After one minute has passed, plug the power supply cable (the small black circular one) back in. (This step is necessary to reset the printer.) Turn the printer off by pressing the green power button. Hold down the grey paper feed button. Turn the printer on by pressing the green button. After the printer begins to feed paper, release the grey button. Once the paper exits the printer, press the green button to turn the printer off. If the power light blinks twelve times while no cartridges are installed, there is a problem with the printer. If this is a new purchase, you can also exchange the printer at the point of purchase. If the paper went through the printer as if printing was occurring, you will need to do some more testing. Continue as instructed below. C. To test the ink cartridges: Open the front cover and insert only the black ink cartridge. Make sure that you push it back until it snaps into place. Close the front cover. If the light flashes twelve times, there may be a defect in the black cartridge. If not, proceed to the next step. Turn the printer off using the green power button. Hold down the grey paper-feed button. Turn the printer on using the green button. After the printer begins to feed paper, release the grey button. Once the paper exits the printer, press the green button to turn the printer off. If the light flashes twelve times, there may be a defect in the black cartridge. If a page came through with a black line, your black cartridge is working properly. Now you need to take the black cartridge out and perform the same steps with the color cartridge. If the light flashes twelve times, there may be a defect in the color cartridge. If a page came through with colored lines, your color cartridge is working properly. If one of the cartridges is causing the problem, you will need to replace that cartridge. If it is a new cartridge, please exchange it at the point of purchase. Good luck
Aug 30, 2007 | Lexmark Z53 Color InkJet Printer
Canon Pixma Pro 9000 MARK II InkJet Photo Printer Logo
14 people viewed this question
old marine
old marine
