Question about Motorola Mobility S11-HD Bluetooth Headphones
The left ear is louder and much clearer than the right ear
The lefty ear is louder than the right one what can I do to fix it
    New Friend:
Tried the knife, made it 10% better but no wax to clean, bc a small rubber circle is under the net... 3 good hard plucks made mine work again. Don't be afraid to pluck it hard, I tried it before softer, which didn't work initially. Reassemble, twist it's neck counter clockwise (right ear) and pluck HARD.
Posted on Sep 29, 2016
My Dodge Grand Caravan is making a humming noise as you accelerate, while turning left it stops but gets worse while turning right. I replaced the left front wheel hub and no improvement, I need help
if hub bearing replacement did not fix the noise
when noises are on left and right turns
that has CV joints /drive shafts
would say they are the issue
replace both sides
and replace the left hand hub bearing at the same time
Oct 20, 2016 | Dodge Caravan Cars & Trucks
Soul by ludacris left ear cup problem
BEst to just try to find a repair shop for that sort of thing. Disecting headphones is a risky venture, and 9/10 it results in a frustrated, headphoneless user.
Jan 30, 2014 | SOUL by Ludacris Bolt Signature Series...
How do I fix an eq problem?
It is a skilled work.. Seek tech support.
Jun 03, 2012 | Audio Players & Recorders
My earphones are having an irregular volume problem! The left side is much louder than the right side. I know this can't be normal and even tried to fiddle around with the audio jack to see if I could fix...
could be a lose wire in the right side open it up and find it solder it so it strong and will never be lose again if there is no lose wire solder them all and see if that makes a differences if not i dont know wat u can do
Aug 10, 2010 | Bose in-ear headphones - Black with...
Turtle beach x1-other people can't hear me
check if any of the wires are loose inside the thing that turns up the volume. the left and right ear wires are inside of that. i had the same problem with the right ear, all i had to do was solder the wire back on the chip.
Jul 25, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
I can't hear out of my earphone's right ear?
get ather pair of earphones, check if ipod is the source of problem or simply the cable of your old phones is broke, to fix that you'll havebe familiar with fusing
Jul 23, 2009 | Audio Players & Recorders
One speaker is MUCH louder than the other
It sound like you have a break in the main wire from the computer sound card to your speaker amp OR the plug is not plug in completely plugged in all the way. Try some other speakers or ear buds / head phones to isolate sound card problem or speaker problem.
Jul 07, 2009 | Dell A525 Computer Speakers
H700 Motorola Bluetooth works fine except when I talk
I used this solution and it worked...good luck with yours: http://www.geocities.com/jconkwright/H700fix.html
Apr 02, 2009 | Motorola Mobility H700 Wireless Headset
Sound louder in right Ear!
If its not something simple like a balance control in your player or a bad earbud (try a different set of earbuds w/a 3.5mm jack).
Then try this:
Theres no mention of a balance function in my Itech manual. It could be a loose solder connection on the board. Thats a common thing to happen with and circuit board mounted hardware that goes out of the unit. I.e. to your ears. Ever so slightly move the earbud jack back and forth, up and down and see if you hear static or the volumes change. If so theres 2 things to try....
First try some contact cleaner, spray it on the male jack and plug it in and out of the unit a few times for a simple try at it.
If it still has imbalance then take the cover off, for the jack side of the unit, resolder the little pins of the inside jack to the board (on the backside of the board). Or find someone that can. These units are worth a few bucks to repair IMO.
Hope this Helps
Feb 09, 2009 | Itech Blue Pro Bluetooth Stereo Headphones...
Sound very muffled in right ear bud
Yes, more than likely it is the wax build-up inside the screen of the earbuds. Take a tack and lightly pry the screen out. You will definitely see a noticeable amound of "gunk on the inside. Clean and you will hear a clearer and crisper sound. If you put the screens on flush and press them in they will stay.
Sep 24, 2007 | V-Moda Headset VIBE in Gumetal Black...
Motorola Mobility S11-HD Bluetooth Headphones Logo
95 people viewed this question
Top Motorola Mobility Audio Players & Recorders Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Unlockingcom
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
