Question about KEC Mobile Applications KEC Mobile Vision 9BNL2 9 Color Mobile Television
I got a kec mobile screen but no dvd player what kind do i get
TV no longer power's on. What problem is causing this condition?
If the TV AND the DVD player are not powering on, then it sounds like the problem is at the receptacle or power strip, where the TV and the DVD player are plugged in. Make sure the receptacle or power strip is working. Plug something else in, a lamp, a radio, anything, and see if it works. If it doesn't then the power strip is off or not working or the wall receptacle is not working.
May 25, 2014 | Coby TVDVD2050 20 in. TV/DVD Combo
Cant pick up any channels on the kec tv in my chevy suburban
Please elaborate on the age of the tv. If it is an older tv it is analog, and wont pick up stations that are all digital.
Mar 19, 2014 | KEC Mobile Applications KEC Mobile Vision...
Won't read any DVD's
Have you tried using a CD player cleaner in the unit? Try a "wet" system. One that uses a cd with tiny brushes on it that you pour a little (included) cleaner on it and run it in the player as if it were any other cd. They have worked miracles for me in the past. Also, although I'm not sure about Kenwoods, I have had a number of aftermarket head units and they have all had. "Reset" button on them. I usually find them on the front located behind the faceplate. Simply remove cd's, press and hold button (with ballpoint pen) for 10- 20 seconds. This will require you to reset time, memory etc... Good luck!
Jan 16, 2012 | Cars & Trucks
Low/No contrast on main screen
There should be a setup menu for "video" where the brightness and contrast can be adjusted.
Feb 10, 2010 | TruTech LMD-5702RT Portable DVD Player
Dvd player plays dvd but the screen only shows lines & the audio is fine.
Sounds like your av cables may need to be replaced or the DVD is bad. Check that the cables are in the correct ports coming from the DVD player to your television and that the cablesd have also been placed in the correct postitions.
Good luck
Nov 11, 2009 | Drive Mobile Entertainment MOBILE VIDEO 7...
Does anyone make a ez view to rca adapter pvs1960
It would be very easy to have the cable made up by a independent electronics shop. I have made several
myself.
Dec 28, 2008 | Durabrand Two Screen Car DVD Player
Screen is blank when i open it...
on the back, there is an AV IN or AV OUT option, turn it to AV OUT methinks
Jul 22, 2008 | Protron PDV-768 Portable DVD Player
KEC Mobile Applications KEC Mobile Vision 9BNL2 9 Color Mobile Television Logo
26 people viewed this question
Top KEC Mobile Applications Home Security Experts
Lawrence Oravetz
Are you a KEC Mobile Applications Home Security Expert? Answer questions, earn points and help others
