Question about Jenn-Air JCD2295K Stainless Steel Side by Side Refrigerator
Light in fountain stays on, dispenser will not deliver ice or water jcd2389ges
SOURCE: Jenn Air JCD2389GES ice dispenser problem
my ice maker is not making ice.
Posted on Mar 26, 2008
TheRepairGur
  • 27 Answers
SOURCE: JCD2389GES water dispenser over-runs and also starts on own
Low water pressure can be very problematic when it comes to icemaker/water dispenser water inlet valves. If there is low water pressure to the valve, the valve may not seat correctly causing icemaker fill tubes to freeze, icemakers to over/under fill or water dispensers to leak or not shut off fast enough. Check the water pressure to the valve like this:
Turn off the water supply to the refrigerator and remove the water supply line from the water inlet valve behind the refrigerator.
Put the end of the water line in a bucket and turn the water supply on. There should be a good stream of water jetting from the tube. If there is not, the water supply shut off valve is probably plugged and needs to be replaced or there could be an in-line water filter that needs to be replaced. Only use a drill style (non-self piercing) saddle valve http://www.repairclinic.com/SSPartDetail.aspx?s=t-584723-%3d%3di584723&PartID=584723 for the water supply.
If there is a good stream, the water inlet valve that the water line connects to at the back of the refrigerator should be replaced.
*Note: Reverse Osmosis (R/O) systems should never be used to supply water to icemakers.
TheRepairGuru --- www.repairclinic.com
Posted on Jan 27, 2009
  • 28 Answers
SOURCE: I have a jenn air JCD2389GES. Every day I'm
The condensate drain may not be draining into the pan under the fridge or it may have a leak or could even be not connected to the condensate pan in the evaporator.
Another possibility is that your condenser might be dirty or plugged causing the suction line going to the compressor to freeze up and then thaw leaving puddles under the fridge. Clean the condenser (the coil under or behind the fridge) and it should stop.
Over stocking the freezer will cause this as well. If you cover the air return in the freezer the evaporator will freeze up and the suction line will freeze back to the compressor.
Posted on Jul 09, 2009
richroth
  • 9472 Answers
SOURCE: My Jenn-air JCD2389GES has virtually
Most instances of hollow ice cubes indicate that water pressure is not high enough to properly fill the mold in the ice maker. Perform the following checks for water pressure problems:
1. If you have a water dispenser, check for proper water flow. You should be able to dispense at least 3 ounces of water within 5 seconds from your dispenser. If low pressure, replace the water filter.
2. Check your water filter status if you have a water filter on your refrigerator. A used up filter can restrict water flow to your ice maker and water dispenser.
Here is a link to the water filter for your refrigerator.
Posted on Jan 15, 2011
  • 2006 Answers
SOURCE: I have a Jenn-Air refrigerator
Yes it could be either, BUT I would go back and make sure that everything you did to stop it the first time is undone. Is everything setted correctly? Is the switches in the right place?
Neither the solenoid or the microswitch could cause the problem you had before, so I would suspect something is not right with the ice maker itself.
Posted on Jun 16, 2011
I have a jenn-air jcd2389ges. The hole in the door where the ice comes down into your cup is broken. i believe the foam piece is busted
Here is a kit of the most likely parts that you are talking about=> 12001991 Ice Dispenser Solenoid and Door Kit Just disconnect the power and turn water off before beginning to ddisassemble the fispenser components seen here=> JCD2389GES Dispenser Components
1. Unplug the refrigerator power cord.
2. Remove the overflow grille from the housing.
3. Unsnap front cover at the bottom of the housing.
(using a flat blade screwdriver, and tape or pad, twist the screw driver, or pry out the bottom trim using the molded slots in the bottom of the trim panel).
4. Disconnect the front cover switch harness connector and set the cover aside.
5. Disconnect the power wire harness connector (BL/BK and W wires)
6. Disconnect the flapper door heater wire harness connector (if one is present).
7. Release the dispenser microswitch retainers and slide the switches off of their locator pins. Carefully handle the switches so they do not come apart.
8. Disconnect the wires from the terminals of the lamp holder.
9. Remove the two 1/4. hex head screws from the control bracket and remove the control bracket.
10. Remove the 1/4. hex head screw to remove the water fitting (fill spout) from the water dispenser lever.
11. Unsnap the ice guide and remove it from the ice dispenser lever.
12. Remove the air pot by sliding the rear of the air pot out of the slot molded to the dispenser housing and slip the linkage out of the flapper door mechanism assembly.
13. Unsnap the flapper door and remove it from the ice dispenser lever. While you remove the flapper door, carefully guide the flapper door heater wire and connector over the door mechanism assembly.
14. Remove the 1/4. hex head screw securing the dispenser levers pivot retainer to the dispenser housing and remove the retainer.
15. Remove the water dispenser lever.
16. Remove the ice dispenser lever by maneuvering it around the door mechanism assembly.
17. Pull the pin from the door mechanism assembly and remove the spring and mechanism assembly.
18. Reassemble in reverse order.
Need Help let me know, Thanks Sea Breeze
Jul 02, 2012 | Jenn-Air JCD2389G Side by Side...
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Our maytag refrigerator (msd2756) water/ice dispenser continues to randomly turn on and off. Also, dispenser light stays on when freezer door closed, but turns off when freezer door open. Any...
Yes it sounds like you may just have a short circuit below the keyboard overlay=> 61005274 Dispenser Control Board Here is a photo of the fountain parts=> MSD2756GES_Dispenser_Parts and tale a look at the wiring diagram=> SD2756GES_Wiring_Diagram
and follow the directions after clicking. I will be HERE to help or here on Fixya, Please rate this solution, Thanks Sea Breeze
Sep 04, 2011 | Maytag MSD2756GES Side by Side...
Ice maker waterwont tureoff
You either have the=> 4389177 Dual Water Control Valves have gone bad on the dispenser side and remaining open or a defective dispenser switch in fountain. Click Here=> Item 14 KSRD22FKST15 Fountain Parts I don't think the keyboard is the problem in this case. If the water control stays open very long it has been known to damage the solenoid on the water control valve. If you have other questions please let me know, Thanks Sea Breeze
2162361 Micro Switch Click Photo
Jan 16, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker dispenser switch has stopped working - will not dispense ice or water. Can I repair myself? How do you gain access to the switch in the door?
If both have stopped working - it is likely the controller board that has failed.
The plastic trimring around the outside lip of the fountain is just snapped into place.
Start at a corner and gently pry it off.
Then there will be screws holding the assembly in place.
You will find the board behind the fountain.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 08, 2010 | LG LSC26905TT Side by Side Refrigerator
Will not dispense water only ice.
I will need the model number to proceed. But it does sound like the dispenser control has malfunctioned. If you get the number for me will you be able to let me assist you. We will need to test wiring in the keyboard, control board, hinge, back to control board if needed, Let me know, Sea Breeze
Dec 17, 2009 | Maytag Refrigerators
Ice maker not working, no water or ice dispensed.
Cause found to be faulty ice/water control board which is located at the back left hand side of the condensor behind the water solinoid valves.This is the single most expensive part of the ice maker!
Oct 13, 2009 | Westinghouse Refrigerators
The ice maker and water dispenser does not work. There is no power to the exterior dispensing unit on the refrigerator.
I'm assuming you are saying there is no ice and water being dispensed, but that the ice maker is producing ice.
Actual ice maker operation is independent of the fountain which is for dispensing only.
The power is checked at the fountain board on wires Red/Black and White. The door must be closed when doing this check as power goes through the door switch. If no power is present, check the same wires at the connector under the upper door hinge cover.
The next check would be Red/Black to Blue while depressing the actuator pad button.
Outputs off the board are Pink to auger motor, Black to fountain water valve, other Black to fountain light, Violet to cube solenoid, the two brown wires go to the ice chute door solenoid.
The ice maker can be checked by removing the plastic cover up front. Check test points L to N for 120VAC. Short test points T and H to cycle the ice maker. Make sure it does not have ice or water in the mold already, or it will run over.
Of course last but not least, check water to the refrigerator. It is a dual valve and unlikely both solenoids could fail at the same time.
May 04, 2009 | Jenn-Air JCD2295HES Side by Side...
You could have a layer of solid ice at the bottom of your icetray. Remove icetray. Remove any ice in bottom. Reinstall. Be careful there is a connection on the rear of the icetray, you may have to turn it to get it to mesh correctly. Fill with ice and it should work fine. Good Luck.
Feb 24, 2008 | Jenn-Air JCD2295K Stainless Steel Side by...
Jenn-Air JCD2295K Stainless Steel Side by Side Refrigerator Logo
26 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
