Question about Cartier Santos Watches
Gold repair The top half of the gold face has appeared to of tarnished, it looks like the stainless steel, I thought it was gold and not gold plate ? I used bleach today, surly this could not of done this to my watch, I've had the watch for over 12 years with no problems at all, any help would be appreciated
  • samlazenby
    samlazenby Feb 11, 2014
    Forgot to mention it is a Cartier santos ladies watch
SOURCE: watch band repair
Cleaning yellow Nautica plastic or rubber wach bands
Posted on Oct 15, 2007
escapement
  • 2334 Answers
SOURCE: stainless steel band won't snap into my watch
Stainless steel bracelet ends (so called wings) must be curved flush to the watch case.
Another way is to use curved spring lugs (pins).
Posted on Dec 17, 2008
escapement
  • 2334 Answers
SOURCE: Phillipe Stark PH1079 watch - Can't get back off to replace bat
There is nothing wrong with your watch. The problem is in tools the jewellers are using for opening the watch.
Despite being under one roof, watchmaking and jewellery are completely different trades and are miles apart. Jewellers usually are equipped with very basic watch repair tools and the case openers are no exeption.
You have to find your nearest watch repair shop and ask for watchmaker, not jeweller. Any decent watchmaker will have the right tool to open your watch and replace the battery in a matter of minutes.
Do not forget to rate, please.
Posted on Jan 15, 2009
SOURCE: i have a 1970 locman
I don't know if this is the same for you, but on my watch I can pull the winder all the way out for the time setting and then I hit the start button for the chronograph and it will adjust the second hand. Hope this helps.
Thanks,
Eric Pederson
GVDCOPS
Posted on Mar 01, 2009
escapement
  • 2334 Answers
SOURCE: stainless steel band adjustment
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 19, 2009
I got a 10 KT acutron it says its plated but a magnet don't stick to parts of it.is there any solid Gold pieces on it. It also says n9
N9 is the date, 1969.
Magnets will only stick to iron and steel (ferrous metals). Gold is none ferrous, stainless steel usually is non ferrous, as it has a nigh nickel content.
Jul 09, 2016 | Watches
I looked at a daytona two-tone the other day. The edges of the gold parts of the band had turned like a black color. Is this normal?
Most likely a fake watch. Rolex makes white gold, yellow gold, platinum and stainless steel watches. Almost always solid metal parts and not plated. It sounds as the plating on your watch is worn through and the underlying metal is oxidizing.
Mar 11, 2011 | Rolex SS/18kt Daytona
How do I get the battery cover off of the 2005 logoart pitts steeler watch? Has spinning face with gold/silver plated band..
At a watch shop is the only safe way.
I've done it with needle nose pliers and scratched the watch every time.
At the watch shops they have a tool, even most wal marts and sears have watch battery replacement centers where they do it for the cost of the battery (no extra fees)
L8ers
Sep 12, 2010 | LogoArt Pittsburgh Steelers Men's NFL Pro...
Second hand is moving at 4 sec incremants not second by second
This is low battery warning. Replace the battery and the watch will tick as new.
Rate me, please
May 19, 2010 | Ebel 1911 18K Gold Diamond Bezel Stainless...
I have a 7 year old Raymond Weil Women's Parsifal watch, stainless steel, bracelet, rectangular face. The outer face in stainless steel, that has four roman numerals on it, has somehow fallen off, or...
If you are talking about the bezel, which is the bit on the outside of the watch, you should contact the Raymond Weil repair centre SWICO. They repaired my Othello when half the bezel fell off. They had it back to me in no time! Their details are on the Raymond Weil website:
http://www.raymondweiluk.co.uk/t-faq.aspx
Good luck
May 11, 2010 | Raymond Weil Watches Tradition 18K Gold...
Did/does Cartier make tank watches that are gold plated over sterling silver?
ARMANI does NOT DO that. Plating is applied to stainless steel only. Rate me, plz.
Feb 04, 2010 | Watches
Fossil stainless steel earrings needing repair.
Joining Stainless Steel is very difficult, most items being spot welded which is more akin to the engineering rather than the jewellery trade. You might consider affixing a new stem which has a flat plate attached. These can be cemented on and would be hidden when worn and are available widely, I saw them on sale in John Lewis.
Feb 01, 2010 | Fossil Watches
Bought rolex yacht masater 18k white gold on ebay
Jimmy, Put a Paypal Dispute IMMEDIATELY!!!
also go to search > advance search > get member contact info
How much did you pay? the watch is guaranteed a fake. When Fake watches are made they are all marked 18k because they do not make different parts for ones that are going to be stainless steel and ones that are going to be gold plated.
If you need help contact me directly gtomab@gmail.com
-mike consumerwatchguide.com
Dec 30, 2008 | Rolex Yacht-Master 16628 Wristwatch
Watches Logo
32 people viewed this question
Top Cartier Watches Experts
k24674
Jimmy Accardi
Are you a Cartier Watch Expert? Answer questions, earn points and help others
