Question about Harman Kardon AVR 135 Receiver
Center speaker does not work. diagnoses is the output from receiver is not functionin properly.
    Genius:
  • 1,175 Answers
Try another speaker connected in that position with new wires
And, what surround setting are you using for your setup?
Thanks
Posted on May 27, 2014
Why does only center channel speaker work?
Try running a sound test. You should have a test mode that will play a sound through each speaker to see if you have them hooked up correctly. If you still only hear it from the center, unhook the center and connect it to another speaker output, say right front. Run the test again. If you hear something from that center speaker, its the speakers. If not, try each speaker output to make sure the results are the same. If so, you may have an internal board problem.
Good Luck!
Nov 05, 2015 | Denon Avr-1910 Receiver
Sony STR-DH510 Multi-channel AV receiver connected to cambridge soundworks ensemble IV w/ passive subwoofer: no sound from center channel during viewing, or during speaker level test- all other speakers...
The STR directs sound to the center as instructed by its speaker setup. You say the center does not work on calibration. Is it defined?
Prove another speaker does or does not work on the center output. Then we'll know if it's the receiver or the speaker ensemble that has the problem.
Have you checked the manual for this "
There is no sound, or only a very low-level sound is heard from the center/ surround. "?
Aug 03, 2010 | Yamaha DSP-A1 Receiver
Yamaha RX-V365 Receiver when I hook up my center channel it is not audible at all. The R and L speakers work fine when they were located in the FRONT A and FRONT B terminals, but when I moved everything to...
With what signal did you try? Maybe your signal source (DVD/TV or radio) didn't contain any sounds for the center channel.
Go to the Setup menu, Speaker setup / Manual setup and find there item called "Test tone". It will output a test tone to each speaker individually (you will see on LCD which speaker is being tested at each moment). If you will hear a sound from the center now, there is no issue and center is working fine, just your source didn't contain any sound for the center.
If it doesn't work, then either you have faulty cable, faulty speaker or faulty center output of the receiver.
- Try connecting the center speaker to different output of receiver (this will test if speaker is OK).
- Try connecting working LEFT speaker to left output with CENTER cable (this will test if cable is OK).
- Try connecting working LEFT speaker with working cable to the CENTER output (this will test the output of receiver if OK - but use the Test Tone from Setup).
May 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
May 23, 2009 | Kenwood VR615 Receiver
Center channel speaker output problem
Check for the speaker separately for proper working? If needed change the speaker and check it ok.
Jan 07, 2009 | Audio Players & Recorders
Center channel sound output
Its not working correctly I have a few different types of center channels and they all have equal sound no matter how many speakers are in them. Connection in speaker box is bad or you may have a blown speaker
Dec 31, 2008 | Pioneer VSX-455 Receiver
Kenwood VR 505 low sound in center channel
if the cables are ok and the speaker are ok also beside good setting you will have a problem of the output stage in your receiver.
May 06, 2008 | Kenwood VR-505 Receiver
Onkyo TX-DS474 has no center speaker or surround speaker output
1-speaker cable is not connected.
2-surround mode button is set to stereo.
3-center level is set to minimum.
4-center speaker is set to no.
Dec 27, 2007 | Onkyo TX-DS474 Receiver
Sorround Back Speakers not giving proper output
for surround put zone 2 on. if zone 2 is not on the speakers which you hooked in the surround back left and right wont work
Dec 24, 2007 | Denon AVR-1507 Receiver
Harman Kardon AVR 135 Receiver Logo
43 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
