Question about Dell Wireless 2350 Router
Change name How do I change the name of the router to somthing else than my.router?
  • Pi_31415 Oct 28, 2007
    I want to change the name of the server my.router to something useful e.g. wan_router.private_network. I use the router as an access point and have another firewall/router the has the domain private_network. The reason for changing the router name is that the web setup page uses this name. If it is wrong, the tools will not work.
    Export settings to file.
    Edit file as follows;
    Then import the settings.
  • 110 Answers
You would like to change the SSID to something else?
The SSID is the name that is broadcasted, the name that you see when you connect to your network.
  1. Log into the web configuration of your router at http://my.router, or the default address The Enter Network Password login prompt appears.
  2. Type the following text in the user name and password fields: "admin".
In the "Wireless" setup tab:
- Change the default SSID to something meaningful to you, but something that does not give anyone else any hints about your network. For example, using your name or your residence's street address as the SSID is not what you'd call a bright idea.
Posted on Oct 27, 2007
How to change the wifi router name?
Hi Victor,
To change your router's name you will need to log in to router's administrative console through you web browser. Once your signed into the router's admin page, you will need to look for the section for the SSID.
Change the SSID to what you would like and save.
That should then update the router's name.
Hope that helps!
Sep 10, 2014 | Computers & Internet
How to change name that is viewed as wi fi id
Go into the router's wireless settings and change the default SSID to some name you require.
Oct 09, 2012 | Actiontec GT704WG Wireless Router...
How to change wifi name in router
The wifi name you are referring to is called SSID, service set identifier. You can change that by logging onto your routers Web based utility. Open your web browser and type in and it will ask you for a user name and password. If you keep the default user name and password the user name should be admin and the password is blank, meaning there is no password set up. After logging on, click on top tab "Setup" and on the side menu "Wireless". You should be able to change the SSID by typing in a new name in the field "Wireless Network Name". Make sure you save the changes! This should then change the name.
Mar 25, 2012 | D-Link DIR-600 Router
The wireless router seeems to have a problem..there is a yellow triangle on the wireless strrength is a dlink dir 615 router ive reset the router and also the main power supply which has...
There are many reasons why this might be happening.. You could try the following steps..
1) Disconnect the power from router for a minute and reconnect and check.
2) Try changing the wireless channel and Network name and try re-connecting.
3) Check if there is an firmware update for your product and update if any update is available.
4) If none of the above steps work you will need to reset and re-config your router. ( For that you need the CD given with the router and you will need the ISP settings.)
Hope this helped
Feb 07, 2011 | D-Link DIR-615 Wireless Router
How do I secure my wireless connection?
The exact access and setting procedure can be found at Belkins web site.
Disconnect all cables to the router, then, in essence you connect to the router, usually via direct connection and direct your browser to the address specified (somthing like and log into the router. Things that you want to change are ssytem ID, router name, Router access password (RECORD IT!!!!) and set up wireless security. An easy access password would be your home phone or cell phone number. if you make a cryptic password, tape it to the router, as you will forget it when a guest visits and needs access.
Another setting to check is that your router broadcasts it's presence, usually set to yes, but not always, by default.
SAVE settings on EACH PAGE or they do not save, as you go from page to page changing settings.
Oct 14, 2010 | Belkin Computers & Internet
I have Dlink 615 model router. i reset one time and now i want to change again my name and password but i cant log into. I try admin in with the IP address and also my user name and password but i cant get...
When you reset your router the IP address will revert back to its factory default IP address and access information, if you changed the IP address prior to the reset you will have to use the default IP.
default IP: (make sure that your network cards IP address is somthing similar like and not
Default username: admin
Default pass: leave blank
If you are still having issues let me know.
Jun 20, 2010 | D-Link DIR-625 (790069292637) Wireless...
Change router settings
in the browser type and insert your login and password. if you have not change the login name and password then visit to your manufacturer site for default login name and password.... Usualy default login name and password is "admin".....This page will lead you to the router settings....
Hope this has helped you..
May 15, 2010 | 3Com OfficeConnect Wireless Router
How can I setup my Linksys 54g v2.2, with my ZyXel 660r modem from embarq so that I can use my laptop with the routers wifi?
First of all you need to set you modem router to bridge mode. go to this link will explaine in more detail
remember to change the linksys router ip to or somthing different from the modem .
Hughes modems are all set to so simply setting the linksys router to default
you need to change the linksys router IP to somthing different
Oct 27, 2009 | Linksys Wireless-G WRT54G Router
ah i see, i think the name change wont matter, i'ts the ip address of the router you need to change to the next number from the other router or the last number as long as it's in the same series as all your ip addresses.
You will have to get into the second router separately to change its gateway address then link it in the system, but you will have to turn off DHCP in the router so it cannot give out ip address as only one router can do that, which is what i meant in the first solution posting.
Sep 08, 2008 | Computers & Internet
Dell Wireless 2350 Router Logo
365 people viewed this question
Alun Cox
