Question about HydroFarm T5 High Performance 4 Foot System
4 bulbs won't light
One switch doesn't seem to be working
Light doesn,t come on when door opens
Hi there, this sounds like either the bulb or the switch. However your "new bulb @switch" seems to imply that you have already checked them. Can you try to get a multi tester onto the bulb mount to check if there's any current going to the bulb because if it's not the bulb or switch then it has to be the circuit somewhere. I'm sorry but I don't think I have any more suggestions apart from 'put up with no light'. Sorry I can't help any more.
Jun 18, 2015 | Refrigerators
My Whirpool LGB6000KQ1 Dryer -- The drum won't stop turning when I open the door and the light doesn't come on either.....
You have a faulty door switch. Here is the replacement switch.
There is a video on that same parts page to show you how to replace it.
Feb 10, 2013 | Dryers
Horn doesn't work, revrese lights won't come on, and 2 of the 3 break lights won't come on on 1995 Geo Tracker. Fuses are good and bulbs are good.
for how long, 1 day, 1 year , 1 decade? is it a daily driver
or a barn stored, winter car.?
the real question,is there 12v exiting the fuse, the acid test. that.
any volt meter does that in 5min flat.
3rd brake light is bad bulb or corroded socket.
what tranny< 3,4,5,sp.? but in each case it takes a good rev.
switch, if 12v enters said switch and does not exit, its bad.
0v bad,6v rev. path shorted to ground,12v good.
btw, all clamps can short, try 1 new one. in each path all by lonesome. dig?
bulbs good means what.
1: look good.
2: glow when placed on a 12v battery
3:measure 0 ohms with meter (means good or shorted.
4: or they are new and assumed good, (p/n ? what is the p/n?)
head lamps good.? parking lamps, blinker, are all other lamps working. does car start?
Dec 05, 2012 | 1995 Geo Tracker
I have a 2004 Silverado 1500. The rear lights won't turn off, pulled all the fuses associated with lights and they still don't turn off. In addition my right turn signal doesn't flash, both the...
Not sure, but I've heard a bad hazard switch can cause strange problems.
Also, if your truck has a body control module that controls interior and lights, that may be your problem, too. Good luck.
Jan 26, 2012 | 2004 Chevrolet Silverado 1500 Crew Cab
Epson PowerLite 410W projector (used for a smart board in a classroom) won't project anything or even turn on. Power button (maybe lamp indicator light? I don't really know anything about this...)...
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Sep 23, 2011 | Epson PowerLite 410W LCD Projector
When I hit the brakes, the tailight on the driver side won't light up. What's the problem?
check the bulb first, be aware that the newer bulbs fit into a slot that has very thin contacts in them, and the ones on the bulb are the same size, if you try a new bulb, make sure the lights are all off, if it doesn't work, and very gently pry that wire out from the plastic that houses it,, at times they get smashed in there and won't make contact
Sep 05, 2011 | 2004 Chevrolet Cavalier
Headlight not working fuse good bulb good no power to switch
i had the same same problem with my 1992 vulcan 750. more than likely it is your reserve lighting devive located on the right side battery box. have you had a problem with your regulator/rectifier lately or a power surge of some type?
May 19, 2009 | 1992 kawasaki VN 750 Vulcan
Fog Lights won't work
Definitely a ground. Clean everything with light sandpaper. Follow any/all wires and see where it grounds, clean there too. If all else fails, run a new ground wire from the frame to the exact spot you got the bulbs to work (a workaround that usually remains permanent on my cars!).
Aug 07, 2008 | 2002 GMC Sierra
HydroFarm T5 High Performance 4 Foot System Logo
87 people viewed this question
Top Hydrofarm Garden Experts
Craig Butler
Craig Butler
Colin Stickland
Colin Stickland
Ed Hauk
Ed Hauk
Level 1 Expert
Are you a Hydrofarm Garden Expert? Answer questions, earn points and help others
