Question about Whirlpool Dishwashers
GU2800XTVS1 I had trouble with dishwasher not completing the entire cycle. First I replaced the controller (Cntrl-ElecOEM) that helped, but then it didnt complete the drying cycle. So then I replaced the heating element. Now its not sanitizing (completing the sanitizing cycle) the sani light flashes at end of cycle. So it not going to the heat it needs to sanitize. Can anyone help me?
3 Suggested Answers
KOakaKO
  • 135 Answers
SOURCE: Two Green Lights Flash Mid Cycle.
It's possible that there's a fault in the drying heater coil, but I couldn't tell you for sure without looking up your machine. If you could locate the model number tag on your machine and write down the exact model number and serial number, then I could likely give you a more informative answer. ;)
Posted on Aug 10, 2007
  • 120 Answers
SOURCE: my dishwasher has the sanitize option but at the
Check your owners manual to see when the light should come on. If it comes on due to high temps, then the heater element may be bad. Run it, then see if element is hot (be careful !)
Posted on Oct 02, 2009
Whirlpool Dishwasher model GU2800XTVS1 has no lights on the control panel
BI METAL is a fuse, use an ohm meter.select ohms, place one lead on each of the 2 prongs it must read zero. If it reads anything else it must be replaced. If it has already been replaced before you may also have to replace the lead wires. It all comes in a kit and is a pretty straight forward procedure.
Jul 29, 2016 | Whirlpool Dishwashers
Shuts off mid cycle
it is likely the heater or thermostat are faulty. Try to run in short cycle like rinse which works on cold water.
Apr 11, 2014 | KitchenAid KUDS30FXSS Builtin Dishwasher
Runs through entire cycle fine but water is cold
you need replaced the control board its very popular with this dishwashers cost around $220 as i have replaced mine
Apr 07, 2010 | Fisher DD603FCSS Dishwasher
Maytag series 100 dishwasher not completely emptying after cycle
I am having trouble with water not emptying out of dishwasher completely help
Jan 07, 2010 | Maytag Dishwashers
No power
open the control panel and chk for 120 volt at the control board( red and black wires on lhs end of cntrl).if u dont read power then chk for loose or burnt wires in the j box at the rhs bottom corner behind kick panel.and if u read 120 volt at cntrl board then the cntrl board is bad.
Aug 08, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher sticking to one cycle
HI, this will occur when the timer module is malfunctioning. the timer module will need to be replaced asap, if possible. the mechanism has failed.
This applies to the newer model with control boards as well. the timer module and, control boards are principal initiators of the entire wash cycle and, if in anytime, they fail to advance the cycle properly, they must be replaced.
Jul 19, 2009 | Dishwashers
The place where u place the soap won't let all the soap out why
hello. i can help you.
When the detergent cup doesn't open, check these:
Timer
Bi-metal switch or wax motor
Detergent cup, itself
Timer On many dishwashers, a plastic actuator arm mechanically links the timer to the detergent cup. When the timer reaches the proper time in the cycle, the timer activates a lever that opens the detergent cup. If the linkage is broken or defective, the cup stays closed after you've closed it. Check the link and repair or replace it, as necessary.
Bi-metal switch or wax motor A bi-metal switch is a simple electrical device that deforms when electricity is applied to it. The degree of this deformation can be engineered to concise standards.
The timer energizes the bi-metal switch inside your dishwasher door--directly behind the detergent cup--when the detergent cup should open. When energized, the bi-metal switch deforms away from the detergent cup latch, which opens the detergent cup. If the bi-metal switch is defective, it may not deform enough to open the cup. If that happens, you need to replace it.
On some dishwashers, the bimetal switch is wired through the heating element or motor circuit. If the element is broken (or open), or if the motor is drawing low current because of a low-fill situation, the bi-metal switch doesn't open properly.
Newer dishwasher models use a wax motor instead of a bi-metal switch. It's a sealed unit with wax that heats up and pushes a piston through to open the door. The wax motor, controlled by the timer, mechanically opens the door.
Detergent cup, itself The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. If not, you probably need to replace the entire cup assembly
The cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing See "The cycle doesn't complete" section.
Jul 05, 2009 | Electrolux Kenmore 24 in. Built-In...
Running time of dishwasher
Water pre-heating
The cycle doesn't complete If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Mar 14, 2009 | Bosch Dishwashers
Maytag dishwasher MDB9100A---tub refills after cycle completed
Problem is actually a water valve that is near the water inlet. Cost is about 35 bucks to fix unless you listen to the guy on here and pay for parts that you don't need and pay them 20bucks for bad advice. Our total cost to fix this $35 dollar problem was an entire wasted Sat, 2 trips to the appliance repair parts place, $130 for the electrical control board that the "wiz" here said I needed--electronic parts and non returnable so we now have a new one that we didn't need.
Mar 29, 2008 | Maytag MDB9100A Dishwasher
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
