Question about Hotpoint Aquarius WMA42 Front Load Washer
No water supply error
No water supply comes up but the machine will be full to the top with water.
    Prodigy:
    An expert who has answered 500 questions.
  • Hotpoint Expert
  • 517 Answers
Is it dirty water
possible it is from the sink when you do your cleaning
the pipe needs to be lifted higher
Posted on Feb 12, 2014
ERROR CODE 1E SAMSUNG TOP LOADER
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve. TO TEST IT SEE PICS ATTACHED
MAY WANT TO TEST THE WATER PRESSURE SWITCH AS WELL BELOW
Jun 15, 2015 | Samsung SW62ASP Top Load Washer
What does error code IE mean?
The "IE" error code indicates that there is a water inlet problem on an LG washing machine. This code appear's if the washer will not fill to the correct water level. There are 3 possible causes for the IE code.
1) partially or fully closed water supply lines
2) improperly attached supply hoses
3) clogged supply hose filters (on machine and in the hoses).
Nov 20, 2014 | Sears Kenmore Elite 4.5 cu. ft....
How to fix error E17 code on eziset 9.5 kg top loader
Supply problem.
Check to see if water hose is plugged and test water pressure.Check water valve supply shut off.
See if filter is plugged.
Run full cycle w/no clothes in washer. Add 1 cup of vinegar,no soap.
May 03, 2014 | Washing Machines
My machine won't meter water into machine
When doing inside jobs on the machine see that the power line is off the wall mains. Also note which line goes where before dismantling it.
First try turning off the machine for 30 minutes. Disconnect the pipes at the back top of machine, to see if water comes full flow from your water supply. Check the fine filters on the machine inlet entry, they could be blocked, clean out with old tooth brush. Some filters are removable.
The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within 1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear for several minutes then the pressure switch can be the source of the problem.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on some washers.
Inlet valves can be purchased thru the net and fitted by you easily.
Water into machines are not 'metered', it is measured by your flow meter inside the machine. A line going up from your outlet area to your panel above to activate a switch, according to water pressure.
Pl click if helped. There are gud videos on YouTube.
Apr 27, 2013 | Kenmore Washing Machines
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
F20 code comes on
recheck water supply. try different wash cycles see if you have same problem.
Aug 15, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Error code PF
The answer above is from Washerhelp. Here's the full diy help from Washerhelp regarding advice about a washing machine not taking in any water http://www.washerhelp.co.uk/diy-repair-help.html
Nov 04, 2009 | LG WM-2277HW Front Load Washer
Machine went dead with clothes and water in it
with putty knife press in along front edge between top and front about 2-3 ins from outer edges on release clips top will lift up suspect bad lock assembly
Jul 04, 2008 | Kenmore Oasis HE 27082 Top Load Washer
No water entering machine.
It may be that the tray underneath the machine is full of water and this appears to activate the anti flood device and shuts off the water supply. If you remove the panel under the door you should be able to check. There are 2 screws to the side and 2 to the top of the small panel. I am uncertain where the water came from on my machine but this appears to have solved my problem.
Jun 24, 2008 | Miele 24 in. G665 Built-in Dishwasher
Hotpoint Aquarius WMA42 Front Load Washer Logo
15 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
