Question about Maytag Centennial MEDC400VW 7.0 Cu. Ft. Electric Dryer - White
Belt installation broken belt
It wont rinse or spin
Sounds like a broken belt
  1. remove back panel screws
  2. lift out panel
  3. check belts replace if necessary
  4. this is a good time to clean it out also
  5. loosen belt adjuster sometimes the whole motor turns or there's a separate adjuster
  6. install belt tighten
  7. install back panel.
Hope this helps Mike
Mar 20, 2016 | Washing Machines
Would jumped timing cause no fire or no start
It would cause an erratic fire, but probably won't start. If the chain or belt is broken, there will be no fire either. Remove the dist. cap and check to see if the rotor is turning while someone else is cranking the engine over... If not, belt is broken! Another way to check, is to remove the oil cap, if you can see the valves, get someone to crank it over, if they are not moving, belt is broken. In any of these cases, it sounds like it will need a new belt installed!
Sep 04, 2013 | 1997 Mazda MPV
I want to know belt type & size for my ikon ford diesel car model 2004 because belt has broken for aultinator.
Install the belt with 115cms length & 4 grooves.
simply tell 5PK type belt & compare with your broken belt.
Sep 13, 2010 | Ford F-350 Cars & Trucks
I have a broken broken belt but can't get replacement around tension pulley. Kenmore Dryer, Mod: 110 62612100, Ser ML 2202910, Type: DWRJR-ELE-2406028-FM54 Thank you
Make sure you have the correct replacement belt first. If you still have the old broken belt, measure it with a tape measure and do the same with the replacement. The new belt may be slightly shorter because the old one will have been stretched with use. Also check the part numbers again, but Kenmore changes numbers sometimes so that isn't always reliable.
The tensioners can be a little tricky sometimes. You can loosen it up if need be, then install the belt, hold the tensioner in place and tighten it back up. During re-installation, try to keep the belt as straight as possible around the drum so it doesn't take up more space, making it more difficult to install on the tensioner..
Jan 28, 2010 | Dryers
My son has a serpentine belt broken that was installed 2 weeks ago.
Sounds like a defective belt, an improper install, or a bad pulley which is causing wear. Was this belt installed because the last one broke or because it was time to change it?
Dec 12, 2009 | 1993 Ford Taurus
Press the start button and drum doesnt start but the dryer makes a humming noise.
motor running but drum not turning, good chance drum drive belt is broken or has jumped off drive pully.
UNPLUG POWER CORD TO DRYER.
open dryer and look for broken belt, if belt is broken use modle number from dryer to purchas the correct belt for dryer install belt and reasmbele dryer. reconect power and test dryer.
Oct 23, 2009 | Dryers
My frigidaire dishwasher routinely leaves some water in the bottom after it is finished washing and the dishes are always wet on the top
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Jul 19, 2009 | Dishwashers
The belt for the alernator its broken
is it big serpentine belt or
single belts
take whats left of old belt to parts store and matchup size
easy to install just find loosen bolts pull off belt in way after loosened install new belt from inside out to last belt that easy
but the end statment in a momment of laughter is to your statment is replace "the Belt"
Dec 06, 2008 | 1995 Mazda Protege
New belt
First put the belt around the small pulley, shd be the motor pulley i think. Then ease the belt around the big pulley & gently move clockwise if the pulley is on the left side; anti clockwise if you are inserting on the right side. The belt will fall into place. Actually it is very simple.
Apr 18, 2007 | Maytag SAV4655A Top Load Washer
Maytag Centennial MEDC400VW 7.0 Cu. Ft. Electric Dryer - White Logo
21 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
