Question about Sewing Machines
Sewing machine problem
Hi hope you can help. My Wife has the Super Galaxie 2100 an old machine but a good one and it has developed a fault. When I switch the machine on both the pushing dogs and the needle head should initialise the dogs move but the head does not . When I touch the screen to change to other stitch patterns the needle head does not move.It should move to show the selection has been made. It used to move from side to side when selecting say a zigzag stitch. I have put on a new pulse motor thinking that was the problem but it still won't do other stitches only straight stitches .I have also checked the cable from the board to the motor and there are no breaks in the wires. Any help would be appreciated Thank you James
  • 84 Answers
You need to open up the machine and place a few drops of oil around the zigzag mechanism. Afterwards, manually move the mechanism back and forth until it is loose. I would place a couple of drops of oil at each joint when you open up the machine. I would say both top and bottom of the machine to loosen every joint.
Posted on Apr 26, 2017
Trifect7
  • 57 Answers
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Posted on Mar 08, 2008
SOURCE: Will not zigzag
Have the hook timing checked on your machine.
Posted on Oct 10, 2008
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
Posted on May 27, 2009
Zenqi
  • 208 Answers
SOURCE: singer machine needle won't do width in zigzag
It sounds like it needs lubrication on the needle bar frame and linkage.
Posted on Oct 01, 2009
  • 980 Answers
SOURCE: Sewing machine not stitching
Sounds like you need to retime the machine, if you email me I can attach instructions drivewithken@blueyonder.co.uk
Posted on Jun 26, 2010
Looking to buy a embroidery unit to fit my brother super galaxie 3100d or one the will fit please help thanks lyn
Contact the manufacturer. Or you can search online:
Make + Model + the word "embroidery"
You may even find something on eBay or Craigslist.
Apr 22, 2016 | Brother Sewing Machines
Does anyone have a Brother Super Galaxie 3000 needle plate they no longer require or would like to sell. Part Number is XA9844 which is written under the needle plate.
Search for the part on the internet. There are sewing machine parts vendors or sometimes the part will be available on auction sites, ie eBay. You can also look for internet groups who sell sewing machines, parts, accessories, etc.
Feb 04, 2016 | Brother Sewing Machines
Super galaxie 2100
the machine needs to be taken to a sewing machine shop to have the lcd screen checked to see if it needs to be replaced..
Jul 16, 2013 | Sewing Machines
Upper thread keeps braking on brother galaxie 2100
With the pressure foot in the up position, pull on the thread right before the eye of the needle to ensure its not getting snagged up on anything.
Make sure your top tension dial is in the middle setting (usually 4 or 5)
What type of thread are you using? Cheaper thread such as Coats and Clark and old thread is very weak. Check out your local independent sewing dealer and have them recommend thread to you based upon the fabric your using.
hope that helps,
Chris
Jun 06, 2010 | Brother CS-8150 Computerized Sewing...
Cotton breaks on Brother Embroidery Galaxie 2100 machine
Try turning down your top tension setting a bit. If its at 4 or 5, i would turn it down to about 3 ish. Cotton thread is more brittle than polyester and rayon thread.
Hope that helps :)
Chris
Jun 05, 2010 | Brother CE5000 Computerized Sewing Machine
Brother Super Galaxie 2100 - Feed dogs will not lift
Remove needleplate and clean out the built up lint between the teeth of the feeddogs.
When moveng from Feed Down to Up, rotate handwheel one revolution to re-engage.
If neither is a problem and your manual is of no assistance, take it to a service centre to check it out and quote.
Aug 19, 2009 | Brother CS-8150 Computerized Sewing...
Sewing Machines Logo
44 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
