Question about Music
Korg pa1x Key problem
Hi there my name is Mitko from England . i have a korg PA1X keyboard and i found out that there is some problem with some of the keys wich when i play they don't sound good , for example : if i play piano and try to play very soft, some of the keys sound very loud,and some sound double, really weird. is it there some one who can help me please??? that will be great, and if you can tell me step by step the things so i can try to fix the problem. thank u for your time. :)
4 Suggested Answers
joemaffei
  • 3 Answers
SOURCE: a broken key on my keyboard Korg Trinity
I just fixed this exact problem today. It took me a while to figure out how to get to the key bed, but it's not impossible. I'll try to retrace my steps and describe them as well as I can:
- Turn the keyboard upside down on a table with the joystick hanging off the table. To make my directions easier to follow, the joystick should be on your left. When I say "front", I mean towards the keys, "back" towards the knobs.
- Have 3 cups for the different types of screws you'll find. A magnet-tipped screwdriver is *essential*, as some of the screws are hard to get to, and you don't want to lose them in there.
- Start by removing the bottom plate.
- Remove the right side panel -- there should be three bigger screws towards the front, and two smaller ones way down towards the back.
- Here's the tricky part... unplug all connectors from the center board. You might want to take some detailed pictures before you do that because there are some empty sockets on the board. It's actually easy to figure out what goes where because most connectors are of different sizes.
- Unplug the two red connectors that go to the left side of the key bed, and the one that goes to the small board on the key bed, but NOT the small white one. That's the aftertouch cable and it doesn't need to be disconnected.
- Unscrew the center board from the horizontal rail in the middle of the case. There should be 4 screws and a cable tie is connected to each one. There are 3 black screws in the back around the digital output slots (there wasn't a digital card on the Trinity I worked on.) -- unscrew those and remove the board VERY carefully not to pull any wires along the way.
- There are two silver plastic grounding slips -- one on the far left, one on the far right. I know you have to remove the left one, I'm not sure about the right one, but remove it just in case.
- Unscrew the long aluminum piece at the very front, the one that is under the keys when the keyboard is right side up.
- Unplug the small connector off the floppy drive. You can leave the ribbon cable connected. The are 4 screws (I think) that hold the floppy drive in place. Unscrew those and remove the drive.
- There should be 1 more screw holding the key bed in place, and it's right by one of the floppy drive screws. Get that one out and pull the key bed upward using the metal piece in the middle -- it may be stuck to the horizontal rail, even though it's unscrewed. Pry it up gently with a screwdriver if you have to. The key bed should come out. If it doesn't, check what might be keeping it in place. Don't ever force anything out of a keyboard.
OK, that's part one. Part two is fairly easy...
- Set the key bed on a table. Remove the long plastic strip at the top.
- To remove a black key, first you have to remove the two surrounding white keys. Grab the bottom part of the key (where you play it) and push towards the top (where there's a square hole). Pay very close attention to how the key is removed, because reinstalling it is the same way, just reversed (obviously). There's a flat spring underneath the key, don't worry if it pops out. It's pretty self-explanatory how to put it back.
- Remove the black key in the same manner. Most likely, the little tab that hooks the key onto the key bed is chipped or broken. In any case, you will need a new key -- unless, of course, it was just the spring that popped out.
Follow the instructions in reverse order to put it all back together. I typed this by memory, so I may have skipped a step or two. Taking this keyboard apart wasn't as easy as I expected, but not as hard as it looked. It just takes patience and being careful.
I hope this helps!
Posted on Jun 04, 2009
  • 5603 Answers
SOURCE: Need help connecting Korg C-303 (Concert Piano)
Assuming the C-303 has a MIDI out, connect a MIDI cable from the MIDI output of the C-303 to the MIDI input of the symphony module.
Connect two audio cables (mono 1/4 inch) from the symphony module to a suitable audio amplification system OR possibly into auxilary audio input jacks of the C-303, if they exist.
I have a Symphony module but not the piano you have and I have mine connected to a Yamaha organ.
Posted on Aug 29, 2009
  • 5603 Answers
SOURCE: korg pa-50 no sound from right speaker but has sound from left
Several things to check:
If the speakers are cut off when externaal cables are connected to line outs, possibly the jack sensing switch for the right channel thinks that a plug is in there... you might cycle one in and out to see if that might fix.
Another thing is they LIKELY have a PAN control setting and it might be set full left. The external MP3 would NOT be under PAN control, only the keyboard voices would be affected by it.
Posted on Feb 01, 2010
Korg pa800 256mb styles set
I wouldn't recommend doing that, because your OS system could freeze occasionally
Jan 29, 2014 | Korg PA800 61 key Arranger Keyboard Kit
I have a Korg Pa800 and it now has 1 key sounds louder than the others, I dont know if I had pressed something wrong. Please help
hi Peter
try to change to organ sound if is not happened the problem is the rubber contact under the keyboard (clean o change the rubber)
Sep 01, 2013 | Korg Pa800 61-Key Professional Arranger...
Korg M 50
Korg Support advises that they can either provide you end cap or direct you to a retailer. CLICK HERE
May 23, 2012 | Korg M50 61-Key Music Workstation Keyboard...
Music Logo
60 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
