Samsung WA422PRHDWR Service bulletin
Were is the fuse on my samsung wa422 washer
There is no fuse. What was referred to is house power brreaker or fuse.
here is a list of all repair parts
http://www.appliancepartspros.com/search.aspx?model=wa422prhdwr/aa
May 30, 2018 | Samsung Washing Machines
Samsung HE Top Load washer always going off balance. Only 4 months old and Ive had trouble since day 1.
Open this link and chat with Samsung technician .
('http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=N0000651&model_name=WA45H7000AW/A2&model_cd=WA45H7000AW/A2','',800,600)
Jan 04, 2015 | Samsung WA422PRHDWR Top Load Washer...
I have a model RF197ACRS fridge that has water collecting in and under the vegetable crisper.
There is a service bulletin from Samsung about that. Contact Samsung and ask about Service Bulletin # ASC20140703001.
Oct 19, 2014 | Samsung Refrigerators
Samsung WA422PRHDWR/AA not draining
i had a the same issue and my fix ended up being the leveling sensor. repair man said if you tilt your washer to far in any direction it throws it off...hmmm
Dec 27, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
Samsung WA422PRHDWR not filling with enough water
I find that some of my clothes don't seem to get wet enough to clean them properly. I like to use the pre-wash cycle to wet everything thoroughly then the machine goes through the normal wash cycle and it seems to do a better job. Just an idea.
Dec 08, 2012 | Samsung WA422PRHDWR
Wa422prhdwr
either the hot water valve solenoid is bad or not getting power and not opening to blend hot and cold water to get the warm wash water the hot water hose has a screen in line and could be plugged with sediment and restricting hot water flow remove hot water hose and check this first
Oct 27, 2012 | Samsung WA422PRHDWR
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
