Question about Gestetner Office Equipment & Supplies
How to unlock Gestetner 3220 copier machine showing Password Locked
  • Arjama Jana
    Arjama Jana Feb 12, 2014
    When ever i switch on the machine it shows password locked and the control panel does not function...please help me to reset the machine as the administrator of the machine has forgotten the password and now the machine can't be used
    Habit-Forming:
  • 103 Answers
Please press the counter key(123) and tap on the system settings .
Tap on the administrator tools and tab on user authentication .
tap on the the user password and cancel.
All the best of luck.
if any problem, call +233243494871 for help.
Posted on Jun 11, 2014
3 Suggested Answers
santosj27
  • 263 Answers
SOURCE: How do I reset the
You are refering the user password???
You can ask to the administrator of the machine. He can see it on the "address book" of the Web Image Monitor.
If he doesn´t answer your question reply to me and i tell you the way.
Posted on Mar 07, 2011
checkitright
  • 1362 Answers
SOURCE: whats the cause of a blank copy in a copier machine Nashuatec,Ricoh or Gestetner machine
can be several causes.
1-Tansfer rollers or wires broken or not charging.
2- no charge to the drum
3-laser unit --could be the shutter not opening or bad laser(should give a code if bad laser)
4-Developper not charging and transferrring toner.
If you can open machine and cheat door to make copier run, make a copy and stop paper as it gets to drum you should see toner on the drum. If there it is not transferring to the paper problem should be the transfer roller or wires(directly under drum. ) If not you need a tech to determine which one is not working.
Posted on Sep 06, 2012
Nokia 3220 contack services diyor ne yapabilirim
If Your Nokia 3220 shows the Contact service provider message? Means it locked to some Network!!!You need to Unlock it.,...then YOU can use any GSM Network Sim card in the Phone,You need to find which Country's Network it locked now? Then Get the Unlock code from here Prounlocking.com and Unlock it....
Aug 01, 2011 | Nokia 3220
Nokia 3220 showing "phone restricted" problem IMEI
Your cell phone may be locked to a particular cell phoneprovider and in this case it needs to be unlocked to use with a different cellphone service provider. To get the security code/restriction code to unlock thecell phone from the current cell phone provider so you can use the SIM cardwith a different phone provider, Please click on this link and follow myinstructions :- http://www.fixya.com/support/r4049238-unlock_cell_phone If your phone provider does not help you then this WEB siteit provides security codes for a small price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw Try this WEB sites - http://www.unlock-free.com http://www.unlock-zone.com/
Jan 14, 2011 | Nokia 3220
Drivers for 3220 gestetner printer fax
http://www.gestetnerusa.com/supportdrivers.html
Aug 29, 2010 | Gestetner Copier
Jai un probleme avec un copieur Gesttner 3220 . A l ecran il me marque le code sc542 je demande de l aide SVP
Gestetner 3220 is similar to ricoh brand
sc542 means your termistor had to be replaced with new one.
if you know the technique, switch off th copier,the open the lateral door,take out the fuser unit.
under or below it you will find 2 unit termistor with red
contact . Properly replaced both with new unit then reinsert the fuser unit in.
Switch on th copier,reset the machine to sp mode
to get into sp mode ,you have to push yellow[C] button follow by button 1,0,7 then push red button[cancel] for several sconds until the screen show sp mode.
When you in sp mode, switch off the machine,then wait for 1-2 min then switch on the copier, wa la it's working. You should try it and it save your cost.
Apr 13, 2010 | Gestetner Copier
Set key code
on the 3240 you will need to have a jumper installed to remove the key counter. this is a hard setting not a softsetting. you need to remove th inside front right cover. under the cover is a 4 pin clear connector. you need to reinstall the jumper to tell the machine no keycounter is installed. the jumper should be under the cover
Sep 25, 2009 | Gestetner Copier
Nokia 3220 restriction code
imei:351860018288243 model 3220 rh-37
provider: smart
philippines
can anyone help me with my restriction problem?
Jan 25, 2008 | Nokia 3220
My nokia 3220 Phone locked:How to get master security code
Default security code is 12345
Unlock Code - is 5126700231 only if you have given correct IMEI no of your mobile and mobile model no
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so show your appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Nov 28, 2007 | Nokia 3220
41 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
