Question about HP Laserjet Pro Cp1025nw Color Printer
Paper will not feed
Paper roll moves does not grab paper
  • 790 Answers
Both paper tray and rollers are spring loaded.
If you have paper stuck in the feed area, it will not pick up paper.
Try removeing all from unit and power blowing the inside try area.
Posted on Apr 24, 2014
I have an old Sharp EL-1701C calculator and for some reason can not feed a new roll of paper into the unit? Batteries are new and the feed option works well, just doesn't grab the paper roll to start?
you may need to cut the corners off a little bit on the start of the new roll and feed the paper in while advancing with the calculator advance control/button
Dec 10, 2014 | Sharp EL-1701C Calculator
Mp 530 error code 103.0.0
you will see small levers were the paper passes. check if one of them are not stuck.
Oct 20, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Paper will not feed through. The roll bar that normally grabs the paper will not move any quick fixes for this.
If you can get to the rollers, get some fine grit sand paper and rough up the surface a little (Make sure you do it even around the roller, and on all rollers).
I had a similar problem on an old Xerox multifunction fax / printer and it worked fine.
Good Luck
Apr 25, 2010 | Canon Pixma iP6600D InkJet Photo Printer
Paper feed problem
this is the rare case: there could be two problem 1) either some bit of paper would have been stucked inside the printer 2) or else the roller is not smooth. the roller inside the printer helps to draw out the paper gently.
Jun 15, 2009 | HP DeskJet 6122 InkJet Printer
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Putting new paper roll in
It's difficult to see, but the feeder for the paper is on the back of the machine, just below where the roll of paper goes. You'll see a little slot above the opening for the batteries. Feed the paper in here and push the arrow up button above the ON/C button to get the paper feeding through the mechanism. It should pop out at the top!
Jul 29, 2008 | Canon P200-DHIII Calculator
Hp LaserJet 1100: Runs louder than normal and continuously, BUT will not grab paper and print
Fred shine a flashlight down the paper feed throat and see if the feer roller is rotating when the printer tries to print.
I have had to replace many of the feed rolls and separation pads in this series of printer.
the tires get dirty or worn and feed multiple sheets or none at all. check for obstructions as well-sometimes the black mylar sheet which sits in front of the feed roll gets in the way of the paper path and has to be pushed in place. I have also seen paper pieces stuck next to the paper path switch which is visible after removing the toner cartridge. hope this helps.
Mar 28, 2008 | HP LaserJet 1100 Printer
BOUGHT A HR-8TE CALCULATOR AND CANNOT INSTALL THE PAPER ROLL
The V tip worked...but cut it not fold it like I first tried to do...and it worked perfectly
Mar 17, 2008 | Casio HR-8TEPlus Calculator
Tape wont register on this after we changed the tape
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Paper feed
If the print-out is an 'alien-like' one, the problem is on the sensor of the printer. The sensor is on the opposite side of the gears. Under the black cover.
Oct 11, 2007 | Office Equipment & Supplies
HP Laserjet Pro Cp1025nw Color Printer Logo
47 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
