Question about Sewing Machines
My stitch for empisal cresta 2000 is slack, how to make it tight?
I want to make my stitch tighter
    Champion:
  • 276 Answers
Try increasing needle tension little by little
Posted on Feb 25, 2014
2 Suggested Answers
  • 208 Answers
SOURCE: I tried to sew a buttonhole using my brother
You may need to get an engineer to adjust the machine internally
Posted on Oct 05, 2013
Empisal creations and episal EXP889 sewing machines.... which is the better one and more recent model
It really depends on what You envision yourself doing with the sewing machine and then finding the machine that has the most functions that fit your needs.
Empisal 889:
  • 36 Stitch functions
  • Front load bobbin
  • On/off switch
  • Left and middle needle position
  • 18 Stitches
  • 4 Step buttonhole
  • Stitch width control
  • 4.5mm Maximum stitch width
  • Soft cover
  • 4.5mm Maximum stitch length
  • Reverse stitch
  • Twin needle
  • Free arm
  • Carrying handle
  • Uncoupling bobbin winder
  • Clip on, clip off foot
  • Drop feed
  • Sews on buttons
  • Zipper foot
Empisal Expression 889 Sewing Machine Empisal Sewing Machines
Empisal Creations
  • 4 Step buttonhole
  • 19 Built-in stitch patterns
  • Oscillating hook
  • Sews on zips
  • Adjustable stitch length: 0 - 4mm
  • Adjustable zigzag stitch width: 0 - 5mm
  • On / Off swithch
  • Free Arn
  • Accessories
  • Reverse stitching
  • Horizontal spool holder
  • Self uncoupling bobbin winder
  • Cover on accessory compartment
  • Large working surface
  • Thread cutter
  • Adjustable presserfoot pressure
  • Built-in tension
  • Darning plate
  • Fold away carry handle
  • One touch snap on foot
  • Versatile utility stitches
  • Sews through heavy fabrics
  • LED lighting
Empisal Creations Sewing Machine Empisal Sewing Machines
https://www.russells.co.za/empisal-creations-sewing-machine
Dec 11, 2017 | Sewing Machines
What is the tension settings on the empisal model S4D
Tension on sergers will vary based on the type of stitch you want to create. For basic overlocking, the tensions are usually set at the midway point. However, every machine is different, so some tweaking will most likely be required to get the stitch where you want it.
Empisal S4D Instruction Manual
Nov 03, 2016 | Sewing Machines
Can a Empisal Electronic Overlocker 760DE do topstitching?
Thats a 4 thread serger, you cant do a top stitch unless its a 5 thread
Sep 19, 2014 | Sewing Machines
Thread riding on the top
Not sure what you mean by riding on top.
I would guess you mean the upper thread is in a straight visible line with the lower thread just looped around it but very slack.
If this is the case the lower tension(bobbin) needs to be tighter.
Apr 21, 2012 | White Sewing Sewing Machines
My machine
Step 1. Set the upper tension tighter by turning the dial slightly to the right, or looser by turning the dial slightly to the left. (Or by using the electronic control if the sewing machine has one.) This adjusts the tightness of the main thread.
Step 2. Set the lower tension slightly tighter or looser using the dial or electronic control. This adjusts the tightness of the bobbin thread.
Step 3. Cut a small scrap of fabric, preferably the same type you want to sew with.
Step 4. Sew a few test stitches on the scrap. Examine the stitches to see if they’re too tight or too loose. The stitches should lie flat against the fabric, without pulling the fabric or making loops that stick out.
Step 5. Repeat Step 1 to Step 4 again as needed.
Good Luck!!
Thanks
Jul 09, 2009 | Juki Sewing Machines
Singer 221-1 stitching is good on bottom but not on top
pucker is caused by too loose or, to tight adjustment of: the thread tensioners both the bobbin tensioner and, the needle tensioner need to be adjusted: to adjust the needle tensioner turn the side knob clockwise is tighter counterclockwise loosens; the bobbin tensioner is a tiny screw on the bobbin holder adjust both tensioners until your stich loops' both top and, bottom are tight but, the machine does not break the thread
Feb 16, 2009 | Singer Featherweight II 117
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
