Question about Cobra CJIC 350 900 Amp Jumpstarter Powerpack with Air Compressor
My air compressor will not turn on
When I turn the power on the air compressor it does not work
    New Friend:
    Problem Solver:
  • 18 Answers
Your problem in the power supply.
so the power not connected to the drive motor, so that the motor cannot run. and cannot drive the compressor
Posted on Apr 11, 2014
Air conditioner compressor doesn't work when i turn on the ac
There is a timer controlled relay in the system. The compressor does not turn on for at least a couple of minutes if the mains power has been lost. This is to prevent damage to the compressor from unreleased back pressure. Wait for this period. It it still does not switch on you might need to replace this relay or the thermostat.
May 04, 2014 | Heating & Cooling
Kelvinator window air conditioner repair
it can damage the motor solenoid. looks similar to these
motorwiring-cjpkdpr3r0ttdxwtzkam4apy-1-0.jpgpower goes into the capacitor and turns the motor on at a steady speed and builds up power, if it overloads that can happen it will either send full voltage that the motor cannot build up on or no voltage
Feb 22, 2018 | Electrolux Heating & Cooling
Sears Craftsman Air Compressor power problem.
Check the compressor tank for any water, the symptoms are just what you would expect if there is excessive moisture in the tank.
Mar 06, 2012 | Air Tools & Compressors
Air compressor wont start
For air compressor not working,click the link below :---http://repairhelpcenter.blogspot.com/2012/01/air-compressor-wont-start.html
-----------Thanks.
Jan 20, 2012 | Air Tools & Compressors
Can you tell me exactly how to fix my air shocks.....is there a manual pump?
System has no manual pump.system overview is this,air springs at all four wheels,electric valve at each spring,air line from these valves to a compressor under hood and lastly level switches that look at height and run compressor and open valves according to need.most likely the air spring bags are cracked causing leaks to system in turn which over works the compressor.best hope is just no power to compressor,so test for power and ground at compressor and if no power.power it up and raise veh or if there is power the compressor is smoked.
Oct 24, 2011 | 1995 Lincoln Continental
My fedders aircon compressor does not turn on again whenever its thermostat turns it off. what i had to do is unplugged the power cord and turn it on again to work. i already replaced the capacitor. what i...
you have a time delay build in on the pc board of 3 minutes. If it takes longer than 3 minutes check your compressor overload protector, Maybe the compressor is overheating, check your coils for proper air flow. ultimately if the compressor checks ok then it's your board relay. also try testing the temperature sensor ( thermostat)
Oct 03, 2009 | Fedders A6X05F2D Air Conditioner
Power steering stops when I turn on the air conditioning
YES. or the belt may be slipping. does the a/c work? if the belt is tight and the a/c does not work, then the a/c compressor is trying to sieze and will need replacement. if you dont need the a/c disconnect the wires to it.
Sep 19, 2009 | 2000 Chevrolet Tracker
2002 linncoln towncar where is the air supension compressor relay switch,please.
Air suspension needs compressed air for the control of Air Springs (Air Spring is a cylinder like thing which goes up and down when air is pumped in and out of it). For pumping in and out the air, air compressor needs to be switched ON/OFF. Compressor relay connects and disconnects the compressor motor from the power supply ( battery). ----------------- air ride suspension compressor located under the air filter box . ---------------- the Air compressor clutch relay location
is fitted to the left hand inner wing (when viewed from the the driving seat).
the compresser is located on the left hand side of the car under the hood.
once you open the hood remove the air cleaner housing and windshield washer resivor.
there is a panel that you lift up under both of thoese that is where the compresser is located
  1. The air suspension uses a small, separate air compressor under the driver's side left fenderwell, with air lines running to the air bags. On the top of each air bag is a electrical valve. This is a relief valve that allows air to be exhausted when activated, and which senses the amount of air pressure within the air bag to keep both sides equal. These valves are operated via a leveling sensor that is attached to the body of the car and to the rear axle by a movable arm. When the rear of the car drops due to increased load, the arm is pushed up. When the arm is pushed up, it turns on the air compressor and fills the air bags to level the car. When the load is removed and the arm moves down, indicating that the back of the car has risen, the sensor opens the valve on the air bags and allows air to escape, lowering the car.
  2. If the back of the car is low, indicating that the air suspension is not working, and the air suspension light is on, check the fuse first. If the fuse is all right, check the air suspension switch in the trunk and make sure it is on. This switch is used when the car is in for service. Always turn off the switch before lifting the car, because the sensor will think the car is rising and keep the air bag valves open, ruining the rear air suspension.
  3. Turn the ignition key with the engine off. Listen for the compressor to come on while pushing down on the rear bumper. If it does not come on, test the switch terminals for power, using a circuit tester. If one terminal has power and the other does not, replace the switch. If there is power, turn the switch to the off position, raise the vehicle and place it on jack stands in the rear. Inspect the leveling switch on the axle, making sure it is not bent and is connected. Use an ohmmeter for this test. Pull the electrical connector off the switch. Loosen the arm of the switch from the axle. Test the switch with the ohmmeter by checking across both terminals while slowly moving the arm. There should be no continuity with the arm down. As the arm is raised, there should be continuity. If not, replace the switch. If there was continuity, connect the arm and the electrical connector.
  4. Put a floor jack under the axle and raise the axle to the point where it is just beginning to lift the car off the jack stand. Turn on the ignition. Turn the air suspension switch to the "on" position. Use the circuit tester to check for power at the leveling switch. If there is power, turn the air suspension switch to "off" and lower the car. Access the air compressor in the front, under the hood, and check the electrical connector for power. If there is power, check for a good ground. If both are good, replace the compressor. If the compressor works and the car does not rise in the back, replace the air bags.
Sep 11, 2009 | 2002 Lincoln Town Car
Cobra CJIC 350 900 Amp Jumpstarter Powerpack with Air Compressor Logo
523 people viewed this question
Top Cobra Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Cobra Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
