Question about Cobra CJIC 350 900 Amp Jumpstarter Powerpack with Air Compressor
The air compressor will not come on when turned on
Motor turns and pump pully does not. burning up belt.
Air Compressor Trouble-Shooting, Problems, The Causes ...
www.portlandcompressor.com/compressor/trouble-shooting.aspx
Provided below is a general list of common air compressor problems, and a few quick ... Loose pulley, flywheel, belt, belt guard, cooler, clamps or accessories. ... Piston rings installed up-side down. ... Receiver does not hold pressure when compressor is unloaded. ... Turn on power, check fuse, breaker, or motor overload.
Reasons Why an Air Compressor Will Not Build Pressure
fix-my-compressor.com/compressor-will-not-build-pressure/
An air compressor that will not build pressure runs on long past the point where it normally ... air compressor with at least one piston that moves up and down or side to side to pump air - cycles, .... I have an Ingersoll rand 7100 compressor 2stage 175 psi 120 gal tank ... The motor is a 2.5hp 3450 rpms with a 4 inch pulley.
Supercharge your Air Compressor for 20 bucks or less - Sawmill ...
www.sawmillcreek.org > ... > General Woodworking and Power Tools
Mar 16, 2006 - 15 posts - ‎8 authors
I have a 27 gallon belt driven Sanborn (Coleman) compressor and I have been ... I'mnot suggesting they won't compress air or give good service. .... Most any small oil-less compressor will serve a nailor, pump up the snow tires ... A two stagecompressor pumps 20 to 30% more CFM per motor HP thanks to ...
Jan 05, 2016 | Ingersoll Air Tools & Compressors
Tip
How to Adjust an Air Compressor Regulator
  • Plug the air compressor into the appropriate electrical socket. There are a few air compressors that come with a 4-prong electrical cord, but most of them will come equipped with a 3-prong electrical cord. The 3-prong electrical cord is set for use with a standard 110 outlet. The 4-prong electrical cord is generally used for 220 outlets.
  • Turn on the machine.
  • The air compressor should be fill completely to the range from 100 to over 200 per-square-inches, depending on the unit capacity.
  • The manufacture guide will inform you which tools can be used with the unit once it has reached full pressure.
  • The tool should be connected to the air hose and the air hose to the compressor.
  • To drop air pressure you should turn the regulator adjustment knob counterclockwise and to increase the air pressure you should turn it clockwise.
on Aug 27, 2008 | Campbell Hausfeld 04 Gallon Twin Stack...
My air conditioner is blowing warm air on the driver side and cold on the passenger side
see this steps and think with clearly and logically NOT feared. God bless you
checkmark.gif Start with the compressor. Does it engage when you turn on the A/C?
If so, the compressor is working and the A/C system probably contains enough refrigerant to make cold air, so the problem is inside the HVAC unit. Replace the motor that controls the blend air door (this is a difficult job and best left to a professional since it involves tearing apart the HVAC unit -- about an 8 to 10 hour job!).
If the compressor does not engage when you turn on the A/C, see if it will run by jumping the compressor clutch wire directly to the battery (use a fused jumper wire). If the compressor works when you jump it, and the A/C blows cold air, the system contains refrigerant and the fault is likely a bad A/C compressor clutch relay or a bad clutch cycling switch or pressure switch.
If the compressor does not engage when you jump it, the problem is a bad compressor clutch.
If the clutch engages but the compressor does not turn (the belt will start to slip and squeal), the compressor is locked up and you need a new compressor.
If the compressor clutch engages and turns the compressor, but the A/C still does not blow cold air, the system is probably low on refrigerant and needs to be recharged.
Jul 24, 2012 | 2007 GMC Sierra Classic
Air compressor wont start
For air compressor not working,click the link below :---http://repairhelpcenter.blogspot.com/2012/01/air-compressor-wont-start.html
-----------Thanks.
Jan 20, 2012 | Air Tools & Compressors
I have a 99 ford expedition i replaced the air compressor cause the front air shocks were bad and ruined the compressor. and teh rear air bags went flat now that the new compressor is in the rear wont air...
I have a 2001 Expedition, I don't have air bags in the front, the compressor don't work the air shocks. You have rear leveling. When they replaced the (compressor) did they turn the leveling switch back on. you may have air shocks connected to the compressor. Did the rear go down right after or over a couple of days. If the switch is on, turn it off and jack the rear up quiet a bit, make sure both side are quiet equal with each other, like it would be if it where raised by the air bags. Turn your level switch back on with it jacked up or sitting on stands. It may have went down so much that the compressor can't raise them back up.
Jan 04, 2010 | 1999 Ford Expedition
My compressor keeps turning on
the compressor is triggered to come on at a minimum pressure determined by the 'regulator'.leaking air you hear is the cause check petcock @ bottom of tank.check air hose inlet connection,air compressor to tank lines.
Oct 01, 2009 | Air Tools & Compressors
Air conditioner
If the fan blows cold air the compressor is already on.
Jul 18, 2008 | Heating & Cooling
Cobra CJIC 350 900 Amp Jumpstarter Powerpack with Air Compressor Logo
81 people viewed this question
Top Cobra Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Cobra Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
