Question about Xante Ilumina Digital Color Press Printer
Xante fatal error 929 - Xante Ilumina Digital Color Press Printer
    Problem Solver:
  • 13 Answers
Waste Toner Transfer Motor Lock Error
Check Waste Toner Unit Operation
Replace the Waste Toner Motor
Posted on Oct 07, 2014
SOURCE: Xante Cl30 laser printer error
no, but just been told its a P/U issue and going to cost about 300 .replbq{width:100%} var LetterVals = { UIStrings : { __last : 'not used' }, StateDynamic : true, yplus_browser : true, premium_user : true, smsintl : "", SidebarSyncActionType : "read", SidebarSyncAuxActionType : "", SidebarSyncUID : "57", SidebarSyncAuxUID : "", getString : function(id) { var result = this.UIStrings[id]; if ( result == null ) { return "Not translated: '" + id + "'"; } return result; } }
Posted on May 28, 2008
rooboy
  • 24 Answers
SOURCE: Xante Ilumina 512 error code
this error can be caused by a new or existing PC on your network. EXAMPLE: the network settings on new DELL pc's are default set to control the network and repair any conflicts..it seems dells dont like Ilumina's, and they get this error code.
Disable the network control function in the DELL settings.
And this error will not re appear until another dell is installed.
Posted on Jul 23, 2008
rooboy
  • 24 Answers
SOURCE: Xanté Ilumina: 020 fatal error
unplug power. open rear panel (2 thumb screws) check fitting of the ROM chips, restart..
020 relates to Slot A ROM DIMM
May need new ROM, or that CU PCB if unsuccesful
JackHeath
  • 1049 Answers
SOURCE: Xante CL30 Fatal Error 177
I think that's a buffer overflow error, but if you get that error no matter what you print I would check to make sure your memory isn't bad.
Posted on Feb 24, 2009
long05891
  • 13 Answers
SOURCE: please what can I do
the 133 fatal error
C head
after turning ON the power or when cover is closed, the sensor detects that the unit is missing.
1. is an Error message displayed? yes
ICheck the OED head unit.
2 is the LED head properly mounted? no
Turn ON power again
3 Does the Error take place again? yes
Replace the LED head Assy.
Posted on Mar 04, 2013
What is a Fatal Error: 140 on a Xante HSE?
That error is image yellow drum up/down senser. Shut down your printer and reseat the drum make sure it is loose and not tight when placing it into the unit.
Oct 02, 2014 | Xante CL30 HSE Laser Printer
How i can fix this problem 929:fatal error .
May 16, 2014 | Xante Ilumina Digital Color Press Printer
"xante ilumina fatal error 929"
The 929 fatal error
Waste Toner
Transfer Motor
Lock Error.
The waste toner transfer motor is not operating properly. Does the error still occur? Yes
Check to confirm that the waste toner transfer system is operating properly.
Replace the waste toner motor.
Feb 03, 2013 | Xante Ilumina Digital Color Press Printer
230:fatal error with Xante Ilumina
RFID Reader Not Installed
Check Connections. Replace the RFID Relay Board Replace the Engine Board.
Jan 09, 2013 | Xante Ilumina Digital Color Press Printer
Xante ilumina I have an error code 134:fatal error , please help!!!!
LED Head Error
131 = Y Head 132 = M Head 133 = C Head 134 = K Head
Sep 21, 2012 | Xante Ilumina Digital Color Press Printer
Fatal error 142 xante Cl30
it's a problem with cyan ID. clean the cyan drurum's contact and the cointacts inside the printer where cyan drum ''sits''. if not try with a used drum.
Aug 22, 2012 | Xante CL30 HSE Laser Printer
Fatal error 133 xante cl 21. Course for this
yellow led head. swap yellow with cyan and see if the error changes
Feb 14, 2011 | Xante CL30 HSE Laser Printer
Please what can I do to work the machine that says fatal error 133; for xante ilumina
If you are in a Windows OS it means that:
133 JOIN or SUBST command can not be used for a drive that already contains readers joints.
So uninstall your printer and install it again using the best driver.
Nov 10, 2010 | Xante Ilumina Digital Color Press Printer
Feb 13, 2009 | Xante CL30 HSE Laser Printer
Jun 04, 2008 | Xante Ilumina Digital Color Press Printer
168 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
rey francis basa
rey francis basa
Dudeman321
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
