Question about Canon i-SENSYS MF4570dn - Multifunction fax / copier / - 4509B020AA
Scanned document feint
Does not show handwriting clearly
How to clear scan data
Your machine will show 100% and that is correct. It doesn't mean memory full, but rather the amount of memory that is still available. Once you scan a document you will see the memory drop down to 99% or even lower depending on the size of the scan. If you don't see this happening than you are not scanning. Other than that your scan will either go to a folder on your PC or straight to your email. All you need to do is locate the folder it saves your scan in (usually created in your C: drive) or check your email folders including your Spam/Junk mail folders.
May 25, 2016 | Ricoh Office Equipment & Supplies
Why does my Canon Mf 8380 scan anything handwritten very faint and non legible
Is the handwriting black ink? Colours come out poorly on most scanners.
You need to increase the contrast when scanning handwriting.
Jul 07, 2014 | Canon imageCLASS Office Equipment &...
How can I use a document camera in the classroom?
A document camera is a great tool for teaching in the classroom. I use one to demonstrate how to solve problems and to zoom in on a text that we are reading in class. I also use it to display lined paper on a whiteboard. This allows the students more room to practice their handwriting.
Jun 19, 2013 | Office Equipment & Supplies
I have a hand writing document which is been scanned in to an image format and now i want to convert the scanned handwriting document in to normal text which can be editable and searchable
You need OCR software (optical character recognition), though you didn't mention the format of the image format file that you have. You may consider using this freeware software to perform your OCR:
http://download.cnet.com/Screen-Copy/3000-2094_4-10039293.html
Oct 20, 2011 | Sun Java Programming Language (cdj-275)
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
My scanner shows patches of green at the bottom
try a scan in just B&W see what happens
and try to use the software to scan just a part of the work
Jul 29, 2009 | HP Scanjet 3770 Flatbed Scanner
Lexmark X3430 scan won't transfer original doc.
This may not be a solution if you are looking to be able to edit the scanned document. You can try to scan the file to an photo application (like MS Paint or Photoshop), hopefully it will scan it as an image and not perform the OCR processing which is most likely messsing up your scanned image.
Apr 30, 2009 | Lexmark X5470 All-In-One InkJet Printer
Insufficent memory to send scanned document
What model? If it has a touch screen do what it says: In "scanner mode" touch the "status" button on the screen..all scans show up with the status.Touch the appropriate scan, and touch "delete" (or cancel)
Mar 30, 2009 | Ricoh Office Equipment & Supplies
Canon i-SENSYS MF4570dn - Multifunction  fax / copier / - 4509B020AA Logo
old marine
old marine
